2700c Flash cần ae giúp đỡ !!!
Em vừa nhận cây 2700c lên chữ NOKIA rồi treo đơ . Em bỏ nó vô MX KEY , scan , info , buscheck đều không được , em phan cho nó cái ver 9.95 nó báo lỗi như trên ae xem log giùm . Máy còn cứng chưa ai đụng đậy ......
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
Processing MCU file: rm561__09.95.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Boot error: 03 00 72 00
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
Bootstrap failed!
Flashing terminated with error(s) in 55.930 s
