2700 flash mât nguồn
giúp em nó báo
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.29.0
Changing mode...Done!
Searching for phone...Detected P-KEY: 90009699
Init usb communication...
Found
Error reading full info...
Found
Init usb flashing...
Error init usb flashing...
Found
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_x
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98_008.image_x_ctv_id_v2_96897
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 09.07.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... .....................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 2610, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw...
Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 0137FFFF ... Erase result: 0000
Erasing cmt zone 01380000 - 0151FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_x...
Erasing cmt zone 01520000 - 01DBFFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98_008.image_x_ctv_id_v2_96897...
Erasing cmt zone 01DC0000 - 0215FFFF ... Erase result: 0000
Erasing cmt zone 02160000 - 03FBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Error sending cmd data...
Error writing cmt...
em cám ơn nha
máy lúc đầu bị gì bạn,có nước nôi gì không?
lấy cáp usb chạy lại coi bạn đổi box khác coi thử
usb không được thì dùng cáp fbus hoặc đa năng mà flash lại cho nó thôi anh
mang qua Mx múc cho tỉnh dậy anh.cái này lổi cặp rồi anh ơi.e gặp 2 trường hợp vậy rồi xóa full chạy lại ko hết.giải pháp là thay cặp.ok 100%
chuyển box khác flash lại hoặc chuyển usb đi bạn
bạn cho vào cáp đa năng flas lại cho em nó lại thử coi
