N72 mất sóng
ae xem giúp N72 mất sóng dò mạng được em nạp lạy log của nó như vầy ae chỉ em phải làm gì,
Version from phone: 5.0741.4.0.1
Version from file: 50819401.C0
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] - C0859271
Using device: HTI BOX, FW ver: 00.17
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Reading Important data ...
Reading RPL backup ...
Reading Phone IDs ...
SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01]
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 47.40 KB
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
Sending Overflow Loader(0x2E4 bytes) ...
Overflow loader running ..
Sending CustomLoader ...OK
PUBLIC ID: 1A5001120C9E4651188C775B5FA2981511C5AD17
PRIVATE ID: 7E458BB9905F73944966F411BD209DDFC8330DDF
E-FUSE: 43811C39
SEC ROM CRC: F0012002
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading SIMLOCK data ...
Reading CERT data ...
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: 780B97BCC24E57401499846918D850CE973A4C54
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
eBB5ProtocolType: OLD
Storage0: 0001 0002 - 0000 7111 [AMD NA] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
loader not responding (00000000000000)
Read Certificate failed.
NPC_DATA is empty.
SUPERDONGLE_KEY_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to ".rpl"
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Total time for flashing process(boot+erase+write) was 22.595 s
Phone type: RM-180 (Nokia N72)
SW version: V 05wk07v48.1 28-08-07 RM-180 (c) Nokia.
Imei plain: 35308902494971-7
Product code: 0531541
Battery voltage: 4860 mV, current: 104 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353089024949717
Version: SIMLOCK SERVER VERSION 58
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
cho nó cái pm xem sao .không ok thì thay pa
chạy lại không hết thì bạn thử thay 2 con tụ 2n2 xem sao vì dòng này nếu chập 1 trong 2 con này thì máy cũng mất sóng , hình tham khảo của bạn đây
N72.bmp - 4shared.com - chia sẻ ảnh - tải xuống ảnh
nhưng cái log này mình thấy hình nhu có vấn đề.
