		2730c nạp đứng mất nguồn
		tình hình là máy sửa rồi bo xấu nhậ mất sóng đang flash lại nó báo vậy là sao nhờ ae coi dùm thanks all. đâ là log của em nó
 MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 1] - C0859FE9
 Using device: HTI BOX, FW ver: 00.17
 Driver: WinUSB, ver: 3.5.0.0
 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
 Processing MCU file: rm578__10.47.mcusw
 [BB5,BB5 ALGORITHM]  size: 21.65 MB
 Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
 CMT Data :
 SYSTEM ASIC ID: 000000010000022600010006030C192101023000
 EM0 ID: 00000296
 EM1 ID: 00000B22
 PUBLIC ID: 23A00103A4CA8C563397E7B2CEADC0768E8D13DD
 ASIC MODE ID: 00
 ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: RAP3Gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 eBB5ProtocolType: OLD
 Storage0: 0089 8982  - 0000 0000 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
 Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
 TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM]  version: 1.31.0 revision: 0.0 size: 0x297E0
 CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
 TransmissionMode: DDR&TX2
 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
 Erase size: 23.25 MB
 CMT FLASH,NOR area [00000000-000006BF]
 CMT FLASH,NOR area [000006C0-0001FFFF]
 CMT FLASH,NOR area [00040000-000BFFFF]
 CMT FLASH,NOR area [000C0000-0013FFFF]
 CMT FLASH,NOR area [00140000-0155FFFF]
 CMT FLASH,NOR area [01560000-0175FFFF]
 erased in 1 min 9.188 s
 Prog.status for Asic CMT ...
 NOR: Success
 Flash programming ...
 CMT NOLO block sent
 CMT KEYS block sent
 CMT PRIMAPP block sent
 CMT PASUBTOC block sent
 CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
 CMT UPDAPP block sent
 CMT DSP0 block sent
 CMT MCUSW block sent
 Error chk C7012D0103CD
 RX2 not responding, please check BSI/cable/pinout !
 Error while programming [00] at 0x0091C400, Result: 0000
 Task failed at (0800001C)!!!
 Last RX buffer: C7 01 2D 01 03 CD 00
		Lấy cái cáp USB ra flash lại coi.lên lại rồi tính
