NHỜ AE XEM GIÚP CÁI LOG 2700c
tình hình là em vừa mới nhận cây 2700c-2 flash thì nó báo vậy không biết thế nào.nên nhờ ae xem giúp.va đây là log em nó
Number of Image Files: 3
Processing Image File :
E:\FILE-NOKIA\RM-561-2700C\rm561__09.98.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1256
Entry Point : 0x5047
Page Format : 128K
Maximum Page Size : 0x00004000
Changing MODE : FLASH
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 05E00112
ID DWORD 1 : BD1C0356
ID DWORD 2 : 96B22B96
ID DWORD 3 : A48501B5
ID DWORD 4 : 918DC3D3
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum DF
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MessageID : 03
SubBlocks : 03
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 2400 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : D5
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 2400
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
3EA22A1DDA660002E56108DB5072A10F8709443F
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:20
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm561__09.98.mcusw
Total blocks to write : 1256
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5
Block Length : 0F
BB ASIC Index : 00
Error Type : 05
Error Spec : 08
Offending Address : 000406C0
Expected Content : 0000DCA1
Detected Content : 0000CC81
Try to change the Flashing clock...
Flashing FAILED
BB5_WRITE_FlashFile_0
Go to Settings -->
Nokia Settings -->
FBUS DDR&2TX Synchronization Timeout
Change the current value selected to a higher value
and Restart AdvanceBox.exe software to apply it
Operations Failed....
