ACE xem dum log N79 bị gì vậy thanks !
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0874036
Using device: HTI, FW ver: 00.50, SN: 0100C9DE
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0AD00110EC8200526F8BEC085133CE708BF1C74C
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: B2075F4B793BB9017C8C0097C783C543F2A6A303
Processing MCU file: RM-348_32.001_prd.core.fpsx
[BB5,XSR 1.5] size: 103.56 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 165.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0A95FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: B2075F4B [RAP Certificate 77 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 2 min 53.557 s
Processing PPM file: RM-348_32.001_013_prd.language.fpsx
[BB5,XSR 1.5] size: 11.85 MB
Erase size: 29 MB
CMT FLASH,MuxOneNAND area [08260000-09F5FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 20.405 s
Processing PPM file: RM-348_32.001_53.1_prd.customer.fpsx
[BB5,XSR 1.5] size: 7.96 KB
Erase size: 10 MB
CMT FLASH,MuxOneNAND area [09F60000-0A95FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 0.125 s
Processing CNT file: vivien_eno_imaker_ape_only.fpsx
[BB5,XSR 1.5] size: 2.59 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
NAND: OK
CMT SOS*ENO block sent
NAND: OK
Programming completed in 4.555 s
Processing CNT file: RM-348_32.001_003_000_U004.uda.fpsx
[BB5,XSR 1.5] size: 16.16 MB
Erase size: 77.75 MB
CMT FLASH,MuxOneNAND area [0A960000-0F71FFFF]
NAND: OK
NAND: OK
Programming completed in 28.829 s
Total time for flashing process(boot+erase+write) was 3 min 58.344 s
Phone type: RM-348 (Nokia N79)
SW version: V ICPR72_09w18.4 14-10-09 RM-348 (c) Nokia
ApeCoreSw: 32.001
Imei plain: 35604403283753-4
Product code: 0576100
Battery voltage: 3589 mV, current: 280 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
