Kết quả 1 tới 9 của 9
    Thành viên tích cực quang_hhbg's Avatar
    Mar 2011
    bắc giang
    Mặc định 1202 thay cpu xin giup
    tinh hinh la em có cây 1202 thay cpu rùi nhung e không biết cách đồng bộ.xon các anh nào biết giúp giùm em.thanks các anh trước
    em chạy bằng mxbox nó như này
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C086CF06
    Using device: HTI, FW ver: 00.50, SN: 00016ECA
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
    ASIC ID: 0x2293 [UPPCosto ver: 2.0]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
    FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
    Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
    UEM ID: 00304FB5A3BDA66
    ASIC type: 11
    UEM Imei: Empty
    Flash Imei: 35934703031603
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\_BACK.rpl"
    Processing MCU file: rh112_004.030
    [DCT4,DCT4 ALGORITHM] size: 2.29 MB
    Supported Ids: 2293
    UEM ID: 00304FB5:2984DA60
    Area [01000000-0100FFFF] erased in 1.187 s
    Area [01010000-013AFFFF] erased in 1 min 5.953 s
    Area [013B0000-013EFFFF] erased in 4.735 s
    Area [017C0000-017EFFFF] erased in 0.032 s
    Area [01FC0000-01FEFFFF] erased in 0.063 s
    Flash programming ...
    Programming completed in 20.719 s
    File processed in 1 min 41.984 s
    Processing CNT file: rh1120_nai04.03mr
    [DCT4,DCT4 ALGORITHM] size: 110.54 KB
    Supported Ids: 2293
    Area [01380000-013AFFFF] erased in 3.532 s
    Programming completed in 1.047 s
    Content extract fail, continue anyway ...
    File processed in 57.203 s
    Processing PPM file: rh112_004.03mr
    [DCT4,DCT4 ALGORITHM] size: 1.15 MB
    Supported Ids: 2293
    Area [01240000-0124FFFF] erased in 1.141 s
    Area [01250000-0137FFFF] erased in 21.438 s
    Programming completed in 9.297 s
    File processed in 40.109 s
    Total time for flashing process(boot+erase+write) was 3 min 19.328 s
    để ý khu vực post bài cho đúng đã move
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Làm lại Upp,ko đc thay con khác
    Oct 2009
    tân phú-đồng nai
    thừ flash lại bằng hwk coi a.mx nhiều khi cà tưng
    Mar 2011
    bắc giang
    em thay cpu khác rùi vẫn vậy các bác a`?mất công làm rồi nên muốn làm cho bằng đuọc:d
    Mar 2011
    bắc giang
    em làm được rồi các bác a`.chạy ngon ngẻ rồi nhưng mở nguồn không lên.hjc
    Thành viên tích cực vietdung702's Avatar
    Jul 2011
    vĩnh phúc
    xem có đứt chân màn hình không
    Thành viên tích cực MR_Sang's Avatar
    đà nẵng
    tét lại cái màn hình ok.
    Mar 2011
    bắc giang
    nó không dao đọng 1 chút j cơ các bác a`?
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    Trích Được post bởi quang_hhbg Xem bài viết
    info xem lock thế nào ,nếu lock đẹp thì kt đường màn hình
  1. 1202 thay cpu xin giup
    By quang_hhbg in forum BB5
    Bài viết cuối: 18-10-2012, 20:41
  2. thay cpu 1202
    By xuanthien8x in forum DCT4 - WD2
    Bài viết cuối: 16-08-2011, 09:40
  3. thay cpu 1202.........
    By huynhphongmobile1 in forum DCT4 - WD2
    Bài viết cuối: 09-08-2011, 23:15
  4. 1202 thay màn hình rồii luôn
    By trongphatmobile in forum DCT4 - WD2
    Trả lời: 29
    Bài viết cuối: 26-02-2010, 11:30
  5. Trả lời: 6
    Bài viết cuối: 21-07-2009, 15:39
