7210c contact service
ae xem hộ log con này cái
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087B3C6
Using device: HTI, FW ver: 00.50, SN: 0100D492
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0160011454CC585044EA07DBBD381546A86D6EE4
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550
CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35574302511975
Original Product code: 0566834
Bluetooth ID: 0022FDE0F957
SIMLOCK PA identifier:
[0] PA_SL2
Phone type: RM-436 (Nokia 7210 Supernova)
SW version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35574302511975-7
Product code: 0566807
Battery voltage: 4873 mV, current: 11 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: 002.010
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355743025119757
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
Log đẹp , bác test màng zin xem sao
tớ đã thử màn zin rồi không có được bạn à
Không cần thay màn
Thay nguồn đi nhé
Nguồn hả bạn? để mình thử xem
thank bác BN Mobile™ . Em thay nguồn ok rồi. Cám ơn bác nhiều
