C3-00 Lỗi Gì Không Biết. Giúp Mình Khám Bệnh Với!
		Mình mới nhận C3-00 cấp nguồn không lên> bỏ pin vào bấm nguồn rung 1 cái rồi im re> cắm cáp vào máy tính cũng không nhận> mxbox nokia usb rom nhận nhưng chạy báo lỗi như vầy>
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08803B1
Using device: USB ROM  and HTI, FW ver: 00.50, SN: 010103DB
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 0000000000386E092912158B0CE5E5190A8CA080
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
 SecondaryBoot: BCM21351_usb2nd.fg [BB5]  version: 11.14.0 revision: 2.1 size: 0x3940
 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000  - 0000 0000  type: RAM, asic:CMT
Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
Storage2: 0000 0000  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030  - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
 Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6]  version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1BF6FC6A
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
Original Imei: 35624704768592
Original Product code: 0594046
Bluetooth ID: AC932F714C35
SIMLOCK PA identifier:
 [0] PA_SIMLOC30
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x178 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Market items is empty, please select the correct products path !
