x2-01 mất nguồn
em nhận 1 con x2-01 da qua sưa chữa flash bằng mxbox thì lỗi báo thế này mong anh emm giúp dỡ MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0872856
Using device: USB ROM and HTI, FW ver: 00.50, SN: 010104D0
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Processing MCU file: rm709__08.70.mcusw
[BB5,XSR 1.6] size: 26.61 MB
Supported Ids: 2200050920030000, 22000509200C0000
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 000053FF
CMT PUBLIC ID: 00000000002C2ABCE94EDCDBF3C0E1F689B491DF
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 36D9154B
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35484204953890_CE RT.rpl).
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 37955B6F [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 11.938 s
Processing PPM file: rm709__08.70.ppm_v
[BB5,XSR 1.6] size: 6.80 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 3.000 s
Processing CNT file: rm709__08.70.image_v_059C6G9
[BB5,XSR 1.6] size: 28.79 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Error while programming [00] at 0x01626000, Result: 0000
bạn kt xem ng ta làm những gì rồi ...cặp đã làm chưa vê sinh sạch sẽ sau đó ....làm nguồn lại ->chạy lại pm xem sao
xem lại cáp đi và coi lại máy làm gì chưa gì múc nguồn đi
ban cho qua box khác flat lại coi thế nào
con nguồn 1 đống nhựa thông... tháo ra nguyên cặp đóng kĩ lại ko hết thay thôi
Cứ làm nguồn đi, ko chết được đâu mà lo :D
