dup minh voi cac ban
lập topic khác đi bạn ơiTrích:
minh da thay man,dong lai hai con kinh dieu khien man ma van ko duoc
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Processing file: rm115__06.60.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 13.00 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 29400118957A6B566027B409BC4CAE1504397E57
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 002F - 0000 6921 [AMD S29NS256N,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A
Erase size: 14.87 MB
CMT NOR area [00000000-000006BF] erased in 0.687 s
CMT NOR area [000006C0-0001FFFF] erased in 0.141 s
CMT NOR area [00020000-0007FFFF] erased in 1.828 s
CMT NOR area [00080000-000DFFFF] erased in 0.172 s
CMT NOR area [00100000-001FFFFF] erased in 0.328 s
CMT NOR area [00200000-002DFFFF] erased in 4.266 s
CMT NOR area [002E0000-00EDFFFF] erased in 51.282 s
CMT NOR area [00EE0000-00EF7FFF] erased in 0.734 s
CMT NOR area [00EF8000-00EFFFFF] erased in 0.172 s
Flash programming ...
CMT PAPUBKEYS: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A (Rap certificate 21 v1) written.
Programming completed in 1 min 36.297 s
Processing file: rm115__06.60.ppm_t as PPM
[BB5,BB5 ALGORITHM] size: 4.83 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 5.37 MB
CMT NOR area [00F00000-0145FFFF] erased in 22.437 s
Programming completed in 35.719 s
Processing file: rm115__06.60.image_t_128 as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 6.38 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 11.50 MB
CMT NOR area [01460000-01FDFFFF] erased in 28.968 s
UCP page size is 128 K.
Programming completed in 47.156 s
Flashing completed in 5 min 59.765 s
Phone not responding !
Total time to process is 11 min 54.984 s
sau khi e chạy bằng mskey kết lối với hwk. Flash xong no báo lỗi
phone not responding, please reset the phone manually then click "ok" to continue !
Backing up SIMLOCK data...
Setting local mode...
Failed! Aborting!
Failed to backup LCK...
Preparing for downgrade...
Failed to prepare for downgrade...
lam lai chan Flash di ban oi .
de lam gi vay Pro
cường Iphone ơi cái này mình làm nhiều rồi bạn thử làm theo xem có ok không naz
như chỉ dẫn của bạn thì UEM và CPU thì ngon lành rồi
trước tiên bạn nên tìm ver cao chạy lại cho em nó bằng cách của mình xem sao
chạy bằng JAF nha bạn
+ bạn chon 4 tick factoryset + mamual flash + normal mode + prod. manager
+ bỏ 2 tick CRT 308 + CRT BKP
+ chọn 3 file MCU + PPM +CNT
——» chú ý : phải là ver cao hơn hoặc = ver cũ là ok
nếu vẫn không được thì mới sờ con flash nhưng mình nghĩ chạy theo cách này là ok thôi chúc thành công nha
mình cũng đã làm theo hướng dẫn của bạn rôi nhưng vẫn không được, jaf, hwk, mxkey cũng ko làm được em này, chuối quá, ae còn cao kiến j không chỉ cho đệ với
log chạy với mxkey ae xem giùm
chạy xong nó báo
phone not responding, please reset the phone click to the continue!
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
RAP PAPUBKEYS is blank/erased.
CMT NOR area [00000000-000006BF] erased in 0.094 s
CMT NOR area [000006C0-0001FFFF] erased in 0.156 s
CMT NOR area [00020000-0007FFFF] erased in 0.187 s
CMT NOR area [00080000-000DFFFF] erased in 0.203 s
CMT NOR area [00200000-002DFFFF] erased in 0.313 s
CMT NOR area [002E0000-00EDFFFF] erased in 2.859 s
CMT NOR area [00EE0000-00EF7FFF] erased in 0.140 s
CMT NOR area [00EF8000-00EFFFFF] erased in 0.156 s
Programming completed in 1 min 37.281 s
Processing file: rm115__06.60.ppm_v as PPM
[BB5,BB5 ALGORITHM] size: 5.04 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 5.37 MB
CMT NOR area [00F00000-0145FFFF] erased in 2.703 s
Programming completed in 37.234 s
Processing file: rm115__06.60.image_v as CNT
[BB5,BB5 ALGORITHM] page size: 64 K size: 5.88 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
CMT NOR area [01460000-01FDFFFF] erased in 4.156 s
Programming completed in 43.454 s
Flashing completed in 4 min 20.531 s
Total time to process is 10 min 33.297 s
buckup rpl lại thay con flash vào, chạy ok lấy mxkey repair lại.
còn cách cuối đó ẵm cặp chương trình qua hong đi gữi file chắc dc d:
