5310 rm303 xin giúp
em đang gặp 1 con 5310 cứ kẹp dòng vào thì máy tự khởi động nguồn em đã thay bo phím khác và chạy lại pm mà không hết mong a e chỉ giúp
e đã thử chạy với jaf, hwk, mxkey mà vẫn không được.
log với hwk: uisetting ngon bình thường.
1ST BOOT : C0,07 [Rm-303] [2.1.0.1]
RAPx ID : 000000010000022600010006010C192101013000
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx PBID : 13A00201FAF30154469C9254F4D6F92C74124B6B
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00EC220C-00008921, Sam K8F1215ETM
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : 3E96DE4212587183E5E16BB2C79692A53C19875D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm303__10.10.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x00140000-010DFFFF
CMT NOR Erase Area: 0x010E0000-0121FFFF
CMT FLASH ERASE OK, Time: 00:50
Written: 8 Certificate(s)
CMT FLASH WRITE OK, Time: 01:42
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
CONVERSION: Already 128K Paged Source
IMAGE : rm303__10.10.image_v_blue
CMT NOR Erase Area: 0x018A0000-01B1FFFF
CMT NOR Erase Area: 0x01B20000-03FBFFFF
CNT FLASH ERASE OK, Time: 00:54
CNT FLASH WRITE OK, Time: 01:00
IMAGE : rm303__10.10.ppm_v
CMT NOR Erase Area: 0x01220000-0189FFFF
PPM FLASH ERASE OK, Time: 00:18
PPM FLASH WRITE OK, Time: 00:37
Flashing Completed, Rebooting Mobile
cho thêm cái log check bắng mixkey lên xem luôn đi anh.
đây log check với mxkey:
EM1 ID: 00000B22
PUBLIC ID: 13A00201FAF30154469C9254F4D6F92C74124B6B
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D
Original Imei: 35865301333866
Original Product code: 0556863
Bluetooth ID: 001D987682FB
Phone Type: RM-303 (Nokia 5310 XpressMusic)
SW Version: V 10.10 23-03-09 RM-303 (c) Nokia
Imei plain: 35865301333866-4
Product Code: 0556863
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358653013338664
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
