5320 nghe nhạc mất nguồn cần giúp đỡ
tình hình em nó như này
log jaf
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 08w35.08
28-11-08
RM-409
(c) Nokia
HW version: 2500
PCI version:
RFIC version:
DSP version:
Retu version: 16
Tahvo version: 22
Production serial number: M1J918421
Product code: 0594812
Module code:
Basic production code: 0557649
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 358228038183807
IMEI spare to net: 3A 85 22 08 83 81 83 00
IMEI SV to net: 33 85 22 08 83 81 83 30 F1
LOCK STATUS:
CONFIG KEY: 0000000000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-409.ini
Setting local mode...
Reading product code...
Product Code: 0594812
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-409\
Checking path: \Products\RM-409\
No ini files found...
Done!
__________________________________________________ _______
log Mx-key
Phone Type: RM-409 (Nokia 5320)
SW Version: V 08w35.08 28-11-08 RM-409 (c) Nokia
Imei plain: 35822803818380-7
ApeCoreSw: 04.13
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SECURITY_TEST passed
Imei net: 358228038183807
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
em đã cho vào mx repair rùi mà vẫ vậy.các bác giúp em với
