em có cây máy 3110c nghe nhạc 2 phút tắt nguồn . nhờ anh em ai biết giúp dùm
chek imei coi đẹp ko bạn
tham khảo ở đây nha bạn 3110c Nghe nhạc nửa bày mất nguồn. [Lưu Trữ] - **** GSM
cho cái log mx key đi bạn cái này mx key repair ok đó
banh 309 con repai dc chứ còn banh RPL thì á
a quăng cái log check len cho ae chiêm ngưỡng cái coi . thường thì có mxkey xử em nó ngọt lun
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 11A0021329047F56CEC7E70B062CBAB807BCFF85
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Original Imei: 35522003179591
Original Product code: 0552795
Bluetooth ID: 0025CF51ECE2
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35522003179591-2
Product Code: 0550691
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355220031795912
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
MCU SW version: V 07.21 05-11-08 RM-237 (c) Nokia.
HW version: 1000
RFIC version: 17211721
DSP version: ICPR61_08w10
PPM version: V 07.21 05-11-08 RM-237 (c) Nokia. V
Retu version: 32
Tahvo version: 53
Content Pack version: Content: v V 07.21 13-01-09 RM-237 (c) Nokia.
Bluetooth ID: : 00 25 CF 51 EC E2
DVB-H receiver Bootloader version: Q
Product Info:
Production serial number: PBN583073
Product code: 0550691
Module code: 0203291
Basic production code: 0542523
Serial Numbers:
IMEI plain: 355220031795912
IMEI spare to net: 3A 55 22 00 13 97 95 01
IMEI SV to net: 33 55 22 00 13 97 95 21 F5
Other Info:
Model : Nokia 3110c (Classic Phone)
CS type : GSM900/GSM1800/GSM1900
BSI: 4.7 KOhm
Counter: 0/3, 0/10
day là log info anh em giup dum voi
lỗi ở chỗ này repair sd =okTrích:
lỗi ở chỗ này
repair sd =ok
chuẩn ko cần chỉnh . làm như a đi bạn .
