log 2700c
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 16A9E647
Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.547 s
CMT NOR area [000006C0-0001FFFF] erased in 0.563 s
CMT NOR area [00040000-000BFFFF] erased in 2.218 s
CMT NOR area [000C0000-0013FFFF] erased in 2.266 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 13.391 s
CMT NOR area [01380000-0151FFFF] erased in 6.907 s
Flash programming ...
CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100000000 (RAP Certificate 202 v.1) written.
Programming completed in 1 min 38.750 s
Processing PPM file: rm561__09.97.ppm_v
[BB5,BB5 ALGORITHM] size: 6.90 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 35.359 s
Programming completed in 35.562 s
Processing CNT file: rm561__09.97.image_v_blac
[BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 15.656 s
CMT NOR area [02160000-03FBFFFF] erased in 2 min 9.297 s
Programming completed in 1 min 5.937 s
Total time for flashing process(boot+erase+write) was 8 min 3.765 s
Device found: nmwcdc\Nokia 2700 classic USB Generic, ID: 39701B35
Flashing completed in 8 min 51.609 s
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.97 18-06-10 RM-561 (c) Nokia
Imei plain: 35199404270286-9
Product Code: 0579808
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351994042702869
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Market items is empty, please select the correct products path !
Nokia USB ROM detached.
Device changed, found new Instance: nmwcdnsuc\Nokia USB Flashing Generic
Nokia USB Flashing Generic ready.
hiên tại bây giờ khởi động thì treo máy và tắt nguồn
mong ae giúp đỡ
chạy lại đi xem ra sao.máy có rơi rớt gì ko.kiểm tra xem có còn r2300 trên máy ko {gần chấu pin }có thể thay xem sao nha ban
