Ultimate Box is first standalone device powered by own OS (Ultimate OS) capable to execute any user code written in Pascal. This is unique solution so far in electronic devices market.
- Features:
Read/Write USB Flash disk,
Send/Receive data over UART port,
Send/Receive data over USB port;
What does this means in practice ? Ultimate Box is capable to comunicate with any electronic device which has either USB or RS232 comunication protocol enabled. In short, Ultimate Box can work with all devices which have a simple connector.
Technical stuff:
Power supply: 5V regulated ( in fact, best results achieved with Nokia ACP-12 charger)
2x USB A ports , 1x RJ45 (RS232) port,
96x64 pixels monochrome graphical display,
5 directions Joystick + enter and reset keys.
How does it works ?
The box it self has operating system built in. User scripts are stored on USB flash disk, and executed from file browser, hence box limitation is equal to actual size of flash disk used. You can store, for example, 1GB of User scripts or flash files on disk, and use it any time.
Motorola plugin features:
- Unlocking:
Direct unlock all LTE and Neptune based models, up to 08.0A bootloader. 08.0A and higher via test point.
Direct unlock all LTE2 based models (V360, V7, U6) using test points. In future posible direct unlock without opening.
Direct unlock all 3G Motorolas, with Micron and Intel flash chips, without opening up to 0.6.3.1 bootloader version, higher via test point. No mater of FW version.
Higher bootloader versions, via test point.
- Relock:
Ultimate Box is capable to relock motorola phones, too.
This is only device which can unlock RSA enabled Motorola phones without using PC based software.
- Backup operations
It is possible to backup/restore any part of phone memory, including full flash backup, or only PDS zone.
- Flashing
Read/Write Firmware
Read/Write Lang pack
Read/Write Flex
- Repair
PDS repair on most models, using full flash and repair script.
Bootloader repair, 0x1DE, 0xDAB and other nasty error messages produced by partial or permanent damage in boot or PDS zone.
Ultimate Box Activation manual:
1. Download Ultimate Box update client
2. Connect power supply to Ultimate Box, press Enter and Reset buttons together, Box will display Serial Number on LCD. Write it down for later use.
3. Start Ultima Box Update client, enter user name, password and Ultimate Box ID, Connect USB Flash disk to PC.
4. Now You can download Activation files and Ultimate Box scripts to Your PC, and install them to USB Flash disk.
5. After Box activation, and installation of scripts, You're ready.
Bonus support area for Ultimate Box users:
1. Go here to register Your account with Ultimate Box ID
2. After registration, You will receive email from server, with activation link
3. Open link in Your browser, and Your account will be activated
Package Contains : 1 X Ultimate Box device
2 X Motorola USB cables
1 X Ultimate Box power supply
For more information, please visit this products webpage.http://www.ultimabox.com/
