các bác xem giùm e log 6220
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 007E [AMD S29NS128J,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 008366EF:2984DA60
ASIC type: 2
UEM Imei: 35100800642348
Flash Imei: 35100800642348
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35100800642348_BA CK.rpl"
Processing MCU file: rh2040pra06.340
[DCT4,DCT4 ALGORITHM] size: 7.17 MB
Supported Ids: 0120, 1120, 1131, 1130
UEM ID: 008366EF:E119DA60
Area [01000000-0100FFFF] erased in 0.625 s
Area [01010000-017FFFFF] erased in 1 min 3.188 s
Area [01800000-019FFFFF] erased in 15.937 s
Area [01A00000-01FEFFFF] erased in 47.828 s
Flash programming ...
Programming completed in 57.484 s
File Processed in 3 min 14.953 s
Processing CNT file: rh2040_06.34.ucp_v
[DCT4,DCT4 ALGORITHM] size: 774.85 KB
Supported Ids: 0120, 0121, 1120, 1131, 1130
Area [01800000-019FFFFF] erased in 16.156 s
Programming completed in 6.172 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.875 s
File Processed in 46.219 s
Processing PPM file: rh2040_06.34v
[DCT4,DCT4 ALGORITHM] size: 1.44 MB
Area [01800000-019FFFFF] erased in 16.078 s
Programming completed in 11.578 s
File Processed in 40.281 s
Total time for flashing process(boot+erase+write) was 4 min 41.469 s
Phone Type: RH-20 (Nokia 6220)
SW Version: V 6.34 31-01-05 RH-20 6220 (c) Nokia.
Imei plain: 35100800642348-5
Imei OTP: 35100800642348
Cellular System: GSM
ASIC ID: 0x1130, type: 2
Ppm Id: V
Language Pack:
English,Chinese S,Chinese T,Vietnamese
Imei net: 35100800642348
Version: SIMLOCK SERVER VERSION 40 - Extended number of TDS-6 boxes
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
MÁY DÙNG 15GIAY LÀ TẮT NGUỒN AH,E KẸP BẰNG MÁY CẤP NGUỒN THÌ HIỆN CHỮ"LOCAL MODE"NHỜ CÁC HUYNH CHỈ GIÚP
