1280 flash done nhưng không lên nguồn
tình hình là thế này.em đang gặp em 1280 rơi nước không lên nguồn.nhưng flash thì ok.mong ae cho ý kiến
đây là log em nó
Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm647_006.500
Downloading item CODE:hw_b2_rm647_r06.500.fls, num block: 3, size: 4.04 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 39.031 s
Erasing area 0x00C60000-0x00E5933E ...OK
Programming completed in 40.766 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.156 s
Checksum verified (0xAE17)
Processing file: rm647_006.50mr
Downloading item CUST:hw_b2_rm647_006.50mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x003288BE ...OK
Programming completed in 20.453 s
Checksum verified (0x52F7)
Processing file: rm6470_nai06.50mr
Downloading item CUST:hw_b2_rm6470_nai06.50mr.fls, num block: 1, size: 305.83 KB
Erasing area 0x00EB0000-0x00EFBA3E ...OK
Programming completed in 6.016 s
Checksum verified (0x342D)
Total time for flashing process(boot+erase+write) was 3 min 5.860 s
Phone type: RM-647
SW version: V 06.50 20-04-11 RM-647 (c) Nokia
Imei plain: 35433804301770-2
Product code: 0593094
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
English,Hindi,Bengali
Imei net: 35433804301770
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
