6230 chay CP Extract Failed!,máy xóa fash ok,nhung nạp vô nó bi loi file cnt bộ sưa tập
có ai gặp ban nay xin giup đỡ
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.260
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.26v
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.26.ucp_v
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,Vietnamese,Chinese S,Chinese T
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.260
Booting phone...
MCU ID: 0x1052
BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
Loader version: 04.40.00 -> Revision: 0007
Boot size is 0x2368
Boot is ready...
FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EC003900 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Flash ID is 0x22F800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
Loader size is 0x8428; Loader chk: 2f
Loader is ready...
P-key nokia module version 01.00
MSID: 8451891A7EC34DB93255F0FBDA
MSID decoded: DC74BAE90043369DA8000000
FAID: 377E313073BBA60D813852B4
Operation took 0 minutes 18 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 007FFFFF...
Erasing area: 00800000 - 0093FFFF...
Erasing area: 00B60000 - 00FEFFFF...
Operation took 2 minutes 11 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 51 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.26.ucp_v
Booting phone...
MCU ID: 0x1052
Boot size is 0x2368
Boot is ready...
Loader is ready...
MSID: 847B48F25277086110EF1137B5
MSID decoded: 3E4EBAE90043369DA9000000
FAID: 24D55AB4E6AEFA592C1C8276
Operation took 0 minutes 17 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 00940000 - 00B3FFFF...
Operation took 0 minutes 19 seconds...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
Extracting Content Pack...
Error setting local mode...
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.26v
Booting phone...
MCU ID: 0x1052
Boot size is 0x2368
Boot is ready...
Loader is ready...
MSID: 84E569EE6BB7BC2E47D3A5D0D6
MSID decoded: 3E4EBAE90043369DAA000000
FAID: 415802BFE54E523ED4565192
Erasing PPM...
Writing...
Operation took 0 minutes 10 seconds...
Restarting MCU...
Flashing Done!
Operation took 5 minutes 50 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Powering the phone...
Failed! Aborting!
ko ai giup hết a
kiếm ver khác nạp thử đi anh . mà lúc đầu máy bị gì mà flash
anh bỏ đánh dấu rpl 208 chạy thử xem
1. Xóa full flash.
2. Cài ver 5.50 ( RH-12_dp_v_174.0_mcusw05.50.exe)
3. Bấm vào ô vuông USE ini, chọn ver 5.50 rồi Flash để chạy, sau viết lại pm, rồi factory setting...unlock
Hy vọng mọi việc là ok. Good Luck.
ko đc ,đã thay cpu voi ic nguon thu ma van bi tinh trang cũ
[QUOTE=vuongnet_gsm;98140]1. Xóa full flash.
làm thủ như bạn này nói đi ..;bỏ vào JAF phang sem thế nào
rồi ,minh có toi 3 thiet bị mà vẫn ko đc
Thay con ROM D455 -> OK!!!
em cam on nhưng thay no mất nguồn luôn rồi
a nhung mà coi lai do là con ram ma d455
neu nhu bị con đó thì nó báo lỗi 6 ,bạn chi mình sai rồi
cấp cứu co ai ko
CHÚ Ý CÁI DẤU TRONG TIẾNG VIỆT NGHE ANH TRAI , RIÊNG TOPIC NÀY CŨNG ĐÃ VI PHẠM HƠI NHIỀU RỒI ĐÓ !!!
bạn đang chạy bằng hộp gì ? bạn thử chạy bằng mt-box xem nó có thể bỏ qua lỗi này được đó bạn bạn vào phần xóa flash , xóa trắng ( đánh dấu hết các file đang tồn tại trong máy bạn ) rồi full lại là ok minh cung bị báo lỗi như bạn nhưng máy mình chưa làm phần cứng nên file flash chạy vô vẫn ổn định chúc bạn thành công
canhchimkhongmoi, đâu rồi giúp 1 tay đi,vẫn ko đc,thay cpu,thay ram ,ic nguồn rồi ma vấn ko đc
