cần anh em xem giùm 1202
		em thay cặp nhưng khi flash nó báo
Using device: HTI, FW ver: 00.24, SN: 00016655
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\35832203979213_BACK.r  pl).
Processing MCU file: rh112_004.030
 [DCT4,DCT4 ALGORITHM]  size: 2.29 MB
 Supported Ids: 2293
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00981FC5:2984DA60
Area [01000000-0100FFFF] erased in 1.140 s
Area [01010000-013AFFFF] erased in 1 min 6.532 s
Area [013B0000-013EFFFF] erased in 4.797 s
Area [017C0000-017EFFFF] erased in 0.031 s
Area [01FC0000-01FEFFFF] erased in 0.031 s
Flash programming ...
Programming completed in 18.266 s
File processed in 1 min 37.469 s
Processing CNT file: rh1120_nai04.03mr
 [DCT4,DCT4 ALGORITHM]  size: 110.54 KB
 Supported Ids: 2293
Area [01380000-013AFFFF] erased in 3.547 s
Programming completed in 1.062 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.109 s
File processed in 20.703 s
Processing PPM file: rh112_004.03mr
 [DCT4,DCT4 ALGORITHM]  size: 1.15 MB
 Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.157 s
Area [01250000-0137FFFF] erased in 21.860 s
Programming completed in 9.172 s
File processed in 38.812 s
Total time for flashing process(boot+erase+write) was 2 min 36.984 s
Phone type: RH-112
SW version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: 35832203979213-6
Product code: 0562324
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MR
Language Pack:
- not available.
Master code: 1372263250
SIMLOCK_DATA corrupted!
 vậy là sao mấy anh
		*Write file pm-->>>unlock la lựn lúa rồi
		Dtc4 thay 1 trong 3 con U,nguồn,flash đêu phải unlock.riêng nguồn hoặc flash phải write thêm RPL
		unlock là ok rồi còn chờ j nửa
		bị contac em đả repai nhưng không có sóng em củng write rồi nhưng củng không được ae ai có pm mất sóng cho mình xin với
		củng không được mấy anh hay do upp để một lúc tự khởi lại anh em cho em xin ý kiến
