Kết quả 1 tới 10 của 13
    Thành viên tích cực pEtrAngXinh's Avatar
    May 2012
    bmt daklak
    Mặc định anh em coi hộ em cái log flash usp c2-03
    em nhận máy vào sài đc 1 lúc là tự tắt nguôn sông tự mở lên lạ em chạy cho em nó phát h trắng mh
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0874392
    Using device: USB Phonet and HTI, FW ver: 00.24, SN: 00015515
    Connection status: UHCI:HUB::USB 1.10 (Full-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2DBD857A
    Device synchronized.
    CPU: XGOLD 213
    Using embedded SBL from MCU.
    Sending EBL Loader...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.46
    EBL version: Quantum_Bootloader_10.46_M1S1
    Protocol version suggested by phone: 3
    Set baud rate to: 6.50 Mbit/s
    Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
    CFI information:
    Flash settings: 0/1024, size: 0x04000000
    1 Block regions:
    512 x 0x00020000 = 0x04000000
    EBL ready !
    Original IMEI:
    RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL)
    Processing file: rm702__06.97.mcusw
    Downloading item CODE:rm702__06.97.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
    Erasing area 0x40000000-0x4001FFFE ...OK
    Programming completed in 0.328 s
    Erasing area 0x40040000-0x4005FFFE ...OK
    Programming completed in 0.343 s
    Erasing area 0x40060000-0x4015FFFE ...OK
    Programming completed in 1.375 s
    Erasing area 0x40280000-0x41D3FFFE ...OK
    Programming completed in 34.281 s
    Checksum verified (0xA701)
    Processing file: rm702__06.97.ppm_v
    Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 5.26 MB
    Erasing area 0x41DC0000-0x42300772 ...OK
    Programming completed in 6.515 s
    Checksum verified (0x5007)
    Processing file: rm702__06.97.image_v_059L5S8
    Downloading item CUSTackage_v_059L5S8.image.fls, num block: 1, size: 11.88 MB
    Erasing area 0x424C0000-0x43E1FFFE ...OK
    Programming completed in 17.187 s
    Checksum verified (0xCB72)
    Total time for flashing process(boot+erase+write) was 9 min 18.297 s
    Waiting for USB device arrival ...
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    yêu em vất vả kết quả trắng tay
    yêu anh vất vả em được tayga..:D
    đưa vô box khác flash lại đi bạn.
    làm cả đời !! hết một giờ
    May 2012
    bmt daklak
    hwk bị lỗi em cài không dc ai cài hộ em với
    Thành viên danh dự minh_dinh_mobile's Avatar
    Apr 2011
    lấy mxbox flash lại coi sao đã
    yahoo.minh_dinh_mobile
    LH.0962.131.123
    May 2012
    bmt daklak
    đã múc 2 lần rồi anh
    CHÂU THÀNH-AN GIANG
    hwk bị lỗi gì mà cài không đc vậy bạn,mình có thể giúp bạn đc ko
    May 2012
    bmt daklak
    tw em đây id 911 794 433 pas 4632
    Moderator VanTuan-ST's Avatar
    Nov 2007
    Sóc Trăng
    Version lúc đầu của máy bi nhiêu, kiếm version cao nhất nạp vô, hoặc chạy die usb by phoenix xem.
    CHÂU THÀNH-AN GIANG
    mình chư co tw đợi mình môt chuc nhá
    May 2012
    bmt daklak
    em sài xp2 nghe mấy bác nói chạy không đc nen em ko cài em đã nạp file cao nhât la 7.94 mà ko done
Hiện có 9 người đang xem bài này . Bao gồm : 0 thành viên và 9 khách
  1. Trả lời: 7
    Bài viết cuối: 07-09-2012, 09:54
  2. Trả lời: 2
    Bài viết cuối: 06-01-2010, 23:17
  3. Trả lời: 3
    Bài viết cuối: 22-06-2009, 17:00
  4. xin files 5310 chip 6225 flash FLASH TOSHIBA TV00578002DABD
    By tuthanwwww in forum Phần mềm và các mã lệnh
    Bài viết cuối: 16-04-2009, 09:46
