nhờ ae xem giùm cái log 1202
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0860294
Using device: HTI, FW ver: 00.50, SN: 0000C47F
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\RPL\35321103023939_BA CK.rpl).
Processing MCU file: rh112_004.030
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
UEM ID: 00532935:2984DA60
Area [01000000-0100FFFF] erased in 0.437 s
Area [01010000-013AFFFF] erased in 24.313 s
Area [013B0000-013EFFFF] erased in 1.453 s
Area [017C0000-017EFFFF] erased in 0.016 s
Area [01FC0000-01FEFFFF] erased in 0.015 s
Flash programming ...
Programming completed in 18.547 s
File processed in 53.000 s
Processing CNT file: rh1120_nai04.03mr
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 1.297 s
Programming completed in 0.891 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.141 s
File processed in 17.188 s
Processing PPM file: rh112_004.03mr
[DCT4,DCT4 ALGORITHM] size: 1.15 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 0.438 s
Area [01250000-0137FFFF] erased in 8.047 s
Programming completed in 9.297 s
File processed in 25.797 s
Total time for flashing process(boot+erase+write) was 1 min 35.985 s
Phone type: RH-112
SW version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: 35321103023939-2
Product code: 0562324
Cellular system: GSM
ASIC ID: 0x2293, type: 0
Ppm Id: MR
Language Pack:
- not available.
Master code: 5760274202
Failed to read SP data
máy mới đầu bị contac mình nạp lại pm thì máy giờ lên logo chữ Nokia rồi đứng im. thay con 8 chân gần ic sim rồi vẫn vậy đóng lai cpu , ic nguồn , gỡ bỏ trở đôi . bác nào biết chỉ giùm mình với.
