1110i em flash bằng atf mà không đồng bộ được.em che cả chân vp mà không được.bác nào chỉ em cách xóa flash con này bằng atf với.em có mỗi box atf nhựa.
cho cái log lên đi bạn
em flash xong bước cuối read mcu thì báo faild
Erasing Done
Flashing ImageFile
ContinueFlash_DCT4 Complete
Write Time Elapse : 00:00:13
FLASH Mode Set to : PHONEMODE_FLASHBUS
ProgrammingStatus_DCT4
BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status
First Byte OK
Second Byte OK
BB_PERM_DATA_RESTORE_REQ : 18 FF
BB_RESTART : 07 FF
MCURestart : SUCCESS
Making delay between files for 6000ms
ImageFile:C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02md
PhoneType : DCT4
Algorithm : DCT4 ALGORITHM
Supported Hardwares :
> 0120
> 0121
> 1021
> 1120
> 1130
> 1131
> 1201
> 2140
> 2142
> 2201
> 2031
> 2030
> 2032
> 2033
Secondary Sending Speed : 100000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 51000Hz
Number of Blocks : 96
Entry Point: 0x00EC
Is128k: True
Boot Check, Please wait...
MCUID Response
MessageID : 92
msbUPP_ID : 22
lsbUPP_ID : 01
Boot OK
Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia
DataLen : 000009D8
Secondary Loader Sent...
Boot OK!
MCU_CONFIGURATION_RESPONSE_DCT4_MUL3
DCT4 Mess 9F MUL3 Mess 9F
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 0020 - ST
DevId0 : 8828 - Type not in database
ExtId0 : 0000
RevId0 : 0121
SectorSize0: 10
Reserved0 : 00
DevAddr1 : 02
ManuId1 : 0000 - Flash
DevId1 : 0001 - not used
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
CheckSum : CD
ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR
SearchForBootstrap_DCT4 : No Error
Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_st_i.fia
ALGO SENT..
Perform AUTHENTICATION..
MSID: 842340D85B3B821F24D54AF4F3
DecodedMSID: 843E4EBAE900143F94AA000000
EncodedFAID: 429FA5F22F26981FD1A0E274
Authentication : SUCCESSFULL
Erasing address:
>> 011E0000 : 011EFFFF
ProgrammingStatus_DCT4 : No Error - 0 (0x00)
>> 011F0000 : 0137FFFF
Erasing Done
Flashing ImageFile
Write Time Elapse : 00:00:11
First Byte OK
Second Byte OK
BB_RESTART : 07 FF
ImageFile:C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02md
PhoneType : DCT4
> 0120
> 0121
> 1021
> 1120
> 1130
> 1131
> 1201
> 2140
> 2142
> 2201
> 2031
> 2030
> 2032
> 2033
Number of Blocks : 11
Entry Point: 0x00E4
Is128k: True
MCUID Response
MessageID : 92
msbUPP_ID : 22
lsbUPP_ID : 01
Boot OK
DataLen : 000009D8
ERROR: Secondary Loader not accepted 07
SearchForBootstrap_DCT4 : Error (Failed)
MCUID Response
MessageID : 92
msbUPP_ID : 22
lsbUPP_ID : 01
Boot OK
DataLen : 000009D8
Boot OK!
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 0020 - ST
ExtId0 : 0000
RevId0 : 0121
SectorSize0: 10
Reserved0 : 00
DevAddr1 : 02
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
CheckSum : CD
ALGO SENT..
MSID: 84C527DAE5CF77FF91D65708EE
DecodedMSID: 843E4EBAE900143F94A8000000
EncodedFAID: 937E379F19D6ACD5251555D6
Erasing address:
>> 01380000 : 013BFFFF
Erasing Done
Flashing ImageFile
Write Time Elapse : 00:00:01
First Byte OK
Second Byte OK
BB_RESTART : 07 FF
Time Elapse : 00:02:15
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
ERROR : PHONE READ INFO FAILED
(em flash xong bước cuối read mcu thì báo faild )
Không biết read MCU làm gì vậy , flash DON thì làm gì chả được ( Kiếm 6.40 chạy thử lại đi )
Kiếm cái jaf cùi chạy bản CR là đồng bộ OK
vầng em cám ơn các bác.may quá em tìm thấy jaf rùi để flash thử coi.
1110i thì cần gì dùng atf, box cùi cũng ok
không được các bác ơi
MCU ID: 0x2201
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 3A 22 08 01 0A 0A 62 49 08 09 C4 41 0E 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: \Products\RH-93\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.930
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.93qa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.93qa
Languages in ppm: English,Chinese S,Chinese T
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.93md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.93md
Languages in ppm: English,Filipino,Vietnamase
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.930
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
Loader size is 0x4B28; Loader chk: cb
Loader is ready...
MSID decoded: 3E4EBAE900143F94AA000000
Operation took 0 minutes 10 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 40 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 12 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.93md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84724DCA7AC304D282B7B707F9
MSID decoded: 3E4EBAE900143F94A9000000
FAID: 77EFA92DEC79AF1CCF775387
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 16 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.93md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 1 minutes 45 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Backup IMEI zone...
Setting local mode...
Failed! Aborting!
Getting MCUID...
MCU ID: 0x2201
Reading flash chip detailes...
MCU ID: 0x2201
Boot is ready...
Algo is ready...
Loader is ready...
Erasing area: 01000000 - 01FFFFFF...
Done!
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Loader is ready...
Operation took 0 minutes 9 seconds...
Erasing...
Writing...
Restarting MCU...
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing PPM...
Writing...
Restarting MCU...
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Operation took 0 minutes 3 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 44 seconds...
Failed! Aborting!
bac nào giúp em phát
đưa qua jaf chạy che chân số 6 lại là factory ok con ko đc tháo hẳn mên ra hấp sấy nóng em nó lên chúc vui
