206 mất nguồn cần anh em giúp gấp
		tình hình là em nhận cây 206 rớt nước mất nguồn, luôc hấp kĩ, kẹp nguồn (không nhấn nút nguồn) kim lên 2 vạch cứ nhịp nhịp hoài không rớt, em đã đóng cặp lại nhưng vẫn not ok, flash lại thì báo. anh em giúp gấp tks all
 rm872__03.58.mcusw
Processing Image File :
 rm872__03.58.ppm_s3
 rm872__03.58.image_s3_059Q477
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 02900C10050E282C
Original Product Code: 059Q426
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\357298057853805\3572980578538  05_113824.rpl
Certificate Block Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\357298057853805\3572980578538  05_CERTIFICATE_0D0F1B31.bin
PM Block Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\357298057853805\3572980578538  05_PMM_PROT_C9F6EBB4.bin
Security Code: 12345
Data Sections : 04
Current File    : rm872__03.58.mcusw
Compile Name: rm872__03.58.mcusw_ebl_psi.fls
Image Type   : Main Firmware
Data Size       : 26480008 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: AFC6
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A66
 Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 5169
 Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
Start Erasing...
Block Erase Done...
Data Size: 25165824 bytes
Data Checksum: 3E66
 Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File    : rm872__03.58.ppm_s3
Compile Name: package_s3.ppm_ebl_psi.fls
Image Type   : PPM Image
Data Size       : 6255108 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41A80000~0x420FFFFE
Start Erasing...
Block Erase Done...
Data Size: 6251764 bytes
Data Checksum: DD0F
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File    : rm872__03.58.image_s3_059Q477
Compile Name: package_s3_059Q477.image.fls
Image Type   : CONTENT Package
Data Size       : 15600912 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42100000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 15597568 bytes
Data Checksum: 5379
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:06:06
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
 WARNING: Phone is not in the Required Mode...
 Disconnect the Phone and Power it Up Manually.
Scanning USB Ports...
ERROR: Active Phone Handle was NOT DETECTED
TIP: Make sure that Phone USB Connection Mode is
OVI Suite Mode
or
PC Suite Mode
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
