bạn xoá trắng flassh chạy lại ok liền. nếu k đc bạn mang wa mt-box thi ngon luôn chúc bạn thàng công
em có con 1208 bi rơi nước ,sấy rồi, cho vào chay PM nó báo FAILED!ABORTing!chay hoài mà vẫn vây
cho em U nó phát lắck đi pồ biết đâu máy lên nguồn chạy phè phè:D
cho cái log lên đây xem sao bạn nhé.
Thay thử cáp khác rồi chạy bạn . Còn nếu không được nữa thì làm lại cpu đi . Chú ý con u cuả nó dễ toi lắm đó nha
Nó báo vậy có nghĩa là ko BOOT dc. bạn vệ sinh,làm CPU lại,thay cáp khác là ok
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.710
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.71aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.71mr
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.710
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84829533C6F190BAD82FCC3B29
MSID decoded: 3E4EBAE900169300A8000000
FAID: F4877E2C0FF91C908D5B4635
Operation took 0 minutes 7 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 10 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 21 seconds...
Writing...
Operation took 0 minutes 8 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 3 seconds...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 2 minutes 23 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
nay u rồi mà vẫn vây
BẠN LẮC NHẸ CON FLASH LẠI ĐI:
rơi nước thì bác lên vệ sinh thật kỹ rồi làm lại chân ic nguồn > cpu > flat đi
Em cũng có cây 1208 như vậy.E đóng lại U bât giờ ko boot đc .Có lẽ phải thay U thôi.Hic
