cấp cúu 1200
MCU ID: 0x2292
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Checking path: \Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ij
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ij
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x6822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 50
Loader is ready...
MSID: 8452F1C1697DF092C1DEC1FDD9
MSID decoded: 3E4EBAE9009DC9E1A9000000
FAID: 706C99247CC0819EE80C3751
Operation took 0 minutes 6 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 0 minutes 23 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84E3C701DE630A75DF345DF38C
MSID decoded: 3E4EBAE9009DC9E1A8000000
FAID: EC4156874574C2F493388CB1
Operation took 0 minutes 10 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 8 seconds...
Writing...
Operation took 0 minutes 7 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 848CA711B12381D5FB3349C6BD
MSID decoded: 3E4EBAE9009DC9E1AA000000
FAID: B1889A9B957141F2B4C97312
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 53 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
máy rớt nước vệ sinh ko lên làm cpu ko đuwowcj thây con khác chạy nó vậy là hư con nào vạy các anh chỉ giúp em ??
cáp khác đi bạn che chân vpp lại flat lại đi 5.71 là chuẩn ok
sory spam!!
post cái nào các bạn hiền ơi!!!
vì thành viên của chúng ta nào Bạn hiền!!!
http://saigonmobile.vn/forum/dong-go...an-giup-2.html
