máy rớt nước mât nguồn dã thay lát dóng lại cpu va uem chạy lại vẫn không lên nho ae xem giúp
dây là log cũa em nó
Getting MCU ID
MCU ID: 0x3162
FLASH ID0: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Failed! Aborting!
Failed! Aborting!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-298\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-298\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-298\rm298__04.90.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-298\rm298__04.90.ppm_ad
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-298\rm298__04.90.image_pov_vodafone_de
Languages in ppm: English,French,German,Turkish
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RM-298\rm298__04.90.mcusw
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
FLASH ID1: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
Flash ID is 0x0822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: a2
Loader is ready...
MSID: 8421FECB3E6A26BC0A2CDF61B2
MSID decoded: 2C40BAE90057AD34A9000000
FAID: 56A909C343937CA7071685C0
Operation took 0 minutes 20 seconds...
Erasing...
Found 2 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 01C3FFFF...
Operation took 0 minutes 58 seconds...
Writing...
Permanent Data Restore FAILED!
Operation took 28 minutes 9 seconds...
Restarting MCU...
Failed! Aborting!
