Cái log 6020
AE xem dùm cái log 6020 này với
MCU ID: 0x2142
FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.220
Booting phone...
MCU ID: 0x2142
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0xF822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: 70
Loader is ready...
MSID: 847D7EC1249B631D4F4CEA5A9B
MSID decoded: 28C7BAE9009DE3F5AA000000
FAID: 3008404051F13D4F5175B401
Operation took 0 minutes 8 seconds...
Erasing...
Found 3 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 0185FFFF...
Erasing area: 01E60000 - 01FDFFFF...
Operation took 1 minutes 41 seconds...
Writing...
Perm. Data Restore OK
Operation took 1 minutes 1 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22.image_v
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 8431BC766C5BA65E54C9C92C72
MSID decoded: 1C15BAE3009DE3F5AD0005BD
FAID: 921A99537878D41CA725798B
Operation took 0 minutes 12 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01A60000 - 01E5FFFF...
Operation took 0 minutes 41 seconds...
Writing...
Operation took 0 minutes 14 seconds...
Restarting MCU...
Extracting Content Pack...
Error setting local mode...
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22v
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader size is 0x7518; Loader chk: 90
Loader is ready...
MSID: 84492177B72378444AD6C4BF05
MSID decoded: 3E4EBAE9009DE3F5AA000000
FAID: 9F99D48C7BFD190EA18ABC3E
Erasing PPM...
Erasing area: 01860000 - 01A5FFFF...
Operation took 0 minutes 20 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 5 minutes 42 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
em đã thay vài chú flash và cpu rồi vẫn vậy máy lúc đầu có bị nước vào đánh sấy xong dùng khoảng 3 ngày tự nhiên chết cạy xong cứ thay nó báo vậy
anh trai nên xem lại con flash nha. em thấy hình như con flash không có DATA (dữ liệu).và không dùng...anh kiểm tra kỉ áp cấp cho flash , có thể thay con khác chuẩn vào lần nữa chạy lại xem có DONE không ,nếu được thì dùng luôn con flash đó rồi chạy đồng bộ lại nha.chúc anh thành công.
