bác nào cho em xin 1 log 1200 asic 11 -Rh-99_353504021391911.ask em cảm ơn trước
mky mấy nay lỗi quá cho minh xin 1log 1200 imel 350604402953127 thanks mình thay ca uem va flash cua 2 con máy khác nhau chu kh cùng 1 cặp
của hoatygontim đây nhớ thanhs nhe bạn
của tranthao đây nhớ thanhs nha lần sau còn giúp
anh cho em hoi lam bằng jaf thì thế nào emchuwa làm bằng jaf bao giờ xin chi giúp
vào phần imei tool rồi witer rpl thôi
báo uem write rùi imel vân ???????mình thay 2con uem và flas
Reading imei...
Opening RPL file...
Inspecting...
IMEI: 35350402139191
Booting phone...
MCU ID: 0x2292
Sending algo...
Algo is ready...
Writting UEM...
UEM Write OK.
Powering the phone...
Repairing BT...
Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Reading...
MCU SW version: V 5.51
16-06-08
RH-99
(c) NMP
HW version:
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w21_U
LCD version: WIN:MYKS:04
ST7507
PPM version: V 5.51
16-06-08
RH-99
(c) NMP
MR
ADSP SW version: V 5.51\n16-06-08\nRH-99\n(c) NMP\nmr
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 6F F1
Master Code: 5013663745
Failed reading simlock data...
Phone type: RH-99, Software version: 5.51, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code:
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Checking path: \Products\RH-99\
No ini files found...
Done!
ae cho e xin iel 6030 thak
asic 2
imel 35808101292252
cần gấp ae ơi
1110i xin giúp log
cho em xin 1 log 1110i... imeil 356806021791587....
