Kết quả 1 tới 3 của 3
    Thành viên mới huynhviet's Avatar
    Jan 2010
    Mặc định 1200 nhờ AE giúp đỡ!!!!!
    Chạy flash như vậy la bị gì vậy mấy anh?
    MCU ID: 0x2292
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
    Checking path: \Products\RH-99\
    No ini files found...
    Phone Type:
    MCU Flash file: C:\Program Files\nokia\Phoenix\Products\1200 RH-99_5.23\rh99_05.230
    Phone Type:
    PPM Flash file: C:\Program Files\nokia\Phoenix\Products\1200 RH-99_5.23\rh99_05.23mr
    Phone Type:
    CNT Flash file: C:\Program Files\nokia\Phoenix\Products\1200 RH-99_5.23\rh990_nai5.23mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\nokia\Phoenix\Products\1200 RH-99_5.23\rh99_05.230
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: d9
    Loader is ready...
    MSID: 840F171BB54E731CDA4011870F
    MSID decoded: 3E4EBAE900C107A0A8000000
    FAID: 6D0484D3703D6B07CF0FCE98
    Operation took 0 minutes 7 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Operation took 0 minutes 36 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 19 seconds...
    Restarting MCU...
    PPM: C:\Program Files\nokia\Phoenix\Products\1200 RH-99_5.23\rh99_05.23mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 842B9D6014309FCED1818842CA
    MSID decoded: 3E4EBAE900C107A0A9000000
    FAID: 176AD69D367A7EB9948750BB
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 11 seconds...
    Writing...
    Operation took 0 minutes 10 seconds...
    Restarting MCU...
    CNT: C:\Program Files\nokia\Phoenix\Products\1200 RH-99_5.23\rh990_nai5.23mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Operation took 0 minutes 0 seconds...
    Flashing Done!
    Operation took 2 minutes 10 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Thành viên kỳ cựu setot_thoi's Avatar
    Aug 2007
    Sóc Trăng
    đem qua BOX khác thử nhé bạn
    Oct 2007
    Kiên Giang
    xóa full nạp lại xem sao?
  1. Trả lời: 3
  2. 1200 xin giúp
    By khanhnokia in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 12-03-2011, 14:21
  3. n-1200 hỏng đèn,xin giúp đỡ!!
    By hienbeomobile in forum DCT4 - WD2
    Bài viết cuối: 07-09-2009, 23:12
  4. 1200 cần giúp
    By mobichat in forum DCT4 - WD2
    Bài viết cuối: 22-07-2008, 23:11
  5. 1200 bệnh lạ cân giúp
    By giakhang84 in forum DCT4 - WD2
    Bài viết cuối: 22-07-2008, 00:26
