Trích Được post bởi hang luong861982 Xem bài viết
MCU ID: 0x2293
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-112\rh112_004.030
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-112\rh112_004.03ic
Languages in ppm: English,Arabic,French,Swahili
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-112\rh1120_nai04.03ic
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-112\rh112_004.030
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84A2D4E7AE65B0369BFE24F7BD
MSID decoded: 3E4EBAE900A1636EA9000000
FAID: BA8B295693F328E44E7F4A2B
Operation took 0 minutes 9 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 2 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-112\rh112_004.03ic
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 19 seconds...
Writing...
Operation took 0 minutes 7 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-112\rh1120_nai04.03ic
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 3 seconds...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 2 minutes 18 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Failed! Aborting!...IMEI
MÁY KHÁCH DANG DÙNG THÌ BỊ MẤT NGUỒN EM CHAY NÓ BÁO THẾ , ANH EM NÀO ĐA GẶP XIN CHI GIÁO
EM ĐÃ ĐẨY LẠI CPU THAY CON 32 MÀ NÓ VẪN THẾ
ông anh chạy ver cao nhất là ok, nếu not ok thi làm theo cách này của em, bỏ tick ở "factory settings" và tick vào "Prod. manager", và tick thêm vào "warranty" , và bỏ tick ở "RPL 208" rồi chạy ver chuẩn là ok . đừng đả động đến UPP làm gì . lại mệt
