em nhận cây 3210 rh-19,bị mất chân ic chuông,em làm xong ok ,thì bị bệnh không hỗ bộ xạc,write cái pm giờ nếu lắp sim vào bật nguồn lên 2s là tắt ngay,mà ko bỏ sim vào ok,gọi 112 cũng bình thường,em làm mềm hết cách rồi,đã chạy nhiều box,nhìn log hoàn hảo, nhuvaanax không được...........log của nó info
MCU ID: 0x1120
FLASH ID0: 7E270100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 06.01
18-03-05
RH-19
(c) Nokia.
HW version: 4834
PCI version:
UEM version: 1092
UPP version: 4384
RFIC version: 03122
DSP version: N4.11
LCD version: SED15G10ITO
PPM version: V 06.01
18-03-05
RH-19
(c) Nok
G
Production serial number: 2BA665027
Product code: 0511593
Module code: 0202204
Basic production code: 0511478
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: 2?
Default SN type: 2?
IMEI plain: 355037009650469
IMEI spare to net: 3A 55 30 07 90 56 40 06
IMEI SV to net: 33 55 30 07 90 56 40 06 F9
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 0235107777
Phone type: RH-19, Software version: 06.01 , Language Pack: G
User code: 12345
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-19.ini
Setting local mode...
Reading product code...
Product Code: 0511593
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-19\
Checking path: \Products\RH-19\
No ini files found...
Done!
mong anh em giúp đỡ
