1208 cần giúp
em chậy con 1208 = jaf đang chạy thì nó báo lỗi như thế này nhờ anh em chỉ giúp xem nó bị làm sao
MCU ID: 0x2292
FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91md
Languages in ppm: English,Filipino,Vietnamase
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x01000000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: d7
Loader is ready...
MSID: 8468CB08C3A5E123FC379347D9
MSID decoded: 3E4EBAE90007AE46A8000000
FAID: E5CC1466F9517CADE1B5041E
Operation took 0 minutes 10 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Writing...
Error cmd: 14!
Addr: 01000000
cảm ơn nhiều
máy bị gì mà chạy vậy anh? kiểm tra cáp, ko được thì múc con Flash. ì
check lại cable . không được làm lại ic nguồn => ok
nạp tửng file xem có hiệu quả không mcu, ppm, cnt từng file một nha bạn , còn không dược nữa thì múc phần cứng nha, kiểm tra ic nguon
ha bạn
Writing...
Error cmd: 14!
Addr: 01000000
Lỏi này khả năng ic flash bị lổi nhiều hơn ic nguồn,múc ic flash trước đi bạn.chúc may mắn.
