1112 bị contact sevice
		Đây là máy 1112 Tàu UPP của máy 6610. Lúc đầu nó bị sóng chập chờn. Em cho mào JAF và Flash một cú, quá trình chạy vẫn bình thường nhưng khi em bật ngồn thì nó bị contact sevice luôn. mong các anh giúp.
Log của nó đây
MCU ID: 0x1120
FLASH ID0: 28882000 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-93
(c) NMP
HW version:
PCI version:
UEM version: 1328
UPP version: 4384
RFIC version: 0500
DSP version: P05w06.v34
LCD version: WIN:MYKS:01
ST7506
PPM version: V 7.02
10-12-07
RH-93
(c) NMP
MD
ADSP SW version: no NAI version
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 355356003551998
IMEI spare to net: 3A 55 53 06 30 55 91 09
IMEI SV to net: 33 55 53 06 30 55 91 49 F5
Master Code: 5463224651
Phone type: RH-93, Software version: 7.02, Language Pack: MD
User code: ÿ#
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code:
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-93\
No ini files found...
Done!
		sao không unlock cho em nó cái anh
		Bạn Thử Unlock Nạp PM chuẩn Coi Được Khôn Bạn
