máy bị rớt nước mình đã làm lai u và nguồn rồi mà không được, log của nó đây,AE xem hộ với,thanks!
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00A5B3DC:DA3BDA66
ASIC type: 11
UEM Imei: 35823003192855
Phone Type: RH-112
SW Version: V 03.00 14-11-08 RH-112 (c) NMP
Imei plain: 35823003192855-0
Product Code: 0562324
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MD
Language Pack:
- not available.
Imei net: 35823003192855
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Invalid UEM Data, No RPL backup will be made for this phone.
FULL FACTORY... Failed!
Completed in 0.609 s
