em thay ic nguồn >> nạp lock bằng mxkey >>unlock bằng mxkey nó bảo lỗi thế này mong ACE giúp đỡ . thanks
Using device: UFS_USB V2.8 (c) SarasSoft 2007.Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C68
UEM ID: 00E64CE6:DA3BDA66
ASIC type: 11
UEM Imei: 35606803426192
Phone Type: RH-112
SW Version: V 03.10 21-01-09 RH-112 (c) NMP
Imei plain: 35606803426192-2
Product Code: 0562324
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 35606803426192
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted
