k đọc las rồi bạn ơi xem lại plass và nguồn đi.
Cái này là giao tiếp giữa flashf và cpu kô có liên lạc ! 98% nằm ở cpu làm chân đóng chuẩn not opk thay mới =ok
1200 chay bang mxkey bao loi xin giúp
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D6E
Using device: HTI, FW ver: 00.50, SN: 0000A1DB
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\RPL\35687302181195_BA CK.rpl).
Processing MCU file: rh99_05.710
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
UEM ID: 00833F9C:2984DA60
Area [01000000-0100FFFF] erased in 0.406 s
Area [01010000-013AFFFF] erased in 24.094 s
Area [013B0000-013EFFFF] erased in 1.641 s
Area [017C0000-017EFFFF] erased in 0.015 s
Area [01FC0000-01FEFFFF] erased in 0.016 s
Flash programming ...
Programming completed in 18.031 s
File processed in 58.656 s
Processing CNT file: rh990_nai5.71mr
[DCT4,DCT4 ALGORITHM] size: 110.62 KB
Supported Ids: 2292
Area [01380000-013AFFFF] erased in 1.204 s
Programming completed in 0.875 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.140 s
File processed in 17.531 s
Processing PPM file: rh99_05.71mr
[DCT4,DCT4 ALGORITHM] size: 1.13 MB
Supported Ids: 2292
Error sending bootloader !
flashing terminated !
xin anh em chỉ giúp
Fl0: 0x01000000-0x01FFFFFF,00000000, UNKNOWN CHIP !
FLASH DEVICE NOT SUPPORTED
khúc này báo không thấy con flash nè bạn ơi Ktra lại chân Flash nhé
