1200 mất nguồn
Processing file: rh99_06.000
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38
UEM ID: 0017CBC7:2984DA60
Programming MCU ...
rh99_06.000:
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
Area [01000000-0100FFFF] erased in 1.172 s
Area [01010000-013AFFFF] erased in 1 min 52.735 s
Area [013B0000-013EFFFF] erased in 8.062 s
Area [017C0000-017EFFFF] erased in 8.640 s
Area [01FC0000-01FEFFFF] erased in 7.937 s
Flash programming ...
Error while programming [1000000] at 0x00000014, Result: 0872
Flashing terminated with error(s) in 2 min 34.984 s
RX Buffer: 0872
ACE xem giúp mình con 1200 của em mất nguồn , chạy thì không được
thay cáp khác chuyển sang box khác chạy lại bạn
MCU ID: 0x2292
Loader version: 04.4F.00 -> Revision: 0007
Boot size is 0x09D8
Boot is ready...
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: BF FF BF FF BF FF BF FF BF FF BF FF BF FF BF FF
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4C68; Loader chk: ff
Loader is ready...
MSID: 8439FC27C9B62C9A02F774E019
MSID decoded: 3E4EBAE90017CBC7AA000000
FAID: 41967CCA7E513316BB468A53
Operation took 0 minutes 12 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Error erasing area: 010F0000 - 0110FFFF
làm chân ic nguồn +lash là ok !!
nếu máy đã qua thợ làm ( đã đụng đến u ) thì nên thay u khác chuẩn rồi flash lại cho nó .
