Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 29
    nnm
    nnm vẫn chưa có mặt trong diễn đàn
    Administrator nnm's Avatar
    Oct 2005
    freelancer
    Mặc định GcPro-Key update new here
    If you just purchase GcPro-Key then you have Register & Active your dongle 1st after that you can use your dongle.
    so here are some steps
    1- Go to Support Area
    Its same link where you get all your Latest Update,Drivers,certs,qcn etc.
    Downloads:
    link1= https://www.mediafire.com/folder/kzd5v0z4fecn7/GCPROKEY
    link2= https://mega.co.nz/#F!1pxHgTBA!P7owR-MlJxD-r0_N6o0xWQ
    link3= https://drive.google.com/folderview?...FE&usp=sharing
    link4= GCPROTEAM bởi gc P. - 4shared
    link5= https://www.dropbox.com/sh/w9gdsem09...Upj32aEVa?dl=0
    link6= https://www.androidfilehost.com/?w=files&flid=120669
    2- Download Latest GCPROKEYupdateXX & CARD Driver & FTDI BOX DRIVER.
    3- Extract to folder not HERE or open from rar GCPROKEYupdateXX.rar, Go to GCPROupdatexx\UPDATETOOL\UPDTOOLOK ,Run GCPROUPDTOOLOK
    4- Install CARD Drivers if needed, Plug Dongle for Registration & Activation ( Make Sure ONLY GcPro-Key Pluged ) Select Register GCPROKEY in GCPROUPDTOOLOK
    5- Watch the Video in case if you feel hard.
    Cty TNHH Công nghệ FYMC - WWW.FYMC.COM.VN
    TK Vietcombank : 0181003368567 - Nguyễn Như Mạnh
    WWW.A-ZGSM.COM
    WWW.VIETFIRMWARE.COM
    Call - Zalo : 0934121179
    Jan 2007
    GcProKey Update50[Motorola ADB enable,frp remove,MTK CDC Port imei repair &much more.
    GcPro Total update count 50 release date 07-04-2017
    GCPROGSMTOOL V1.0.0.0044 released.
    • What's New:
      • Added World's first Motorola ADB Enable via FACTORY MODE all known android os tilldate..
        Note:for steps read gcproupdatexx\helpfiles\Motorola_adb_enable_helpfi le
      • Added World's first HTC Sprint Alternative method for SPC/MSL read.
      • Added World's first Samsung DRK Repair new method.
        Note:Only work via UART at present.
      • Added Samsung imeicert write adb more better support for damaged NV phones.
        • Supported Models
          • SS305
          • SS310AP
          • SS315
          • SS333
          • SS335 etc
          Note: Software will ask you to write other phone nv at run time.Once its successful you can use imeicert write adb again to fix nv.
      • Added Unicode support for options for Chinese,Russian,turkish etc.
        Note: auto languages support is via windows LCID.. software will detect what windows default languages is.
        Note2: all translation can be handle with lang.xml near application for add your own languages support please contact us via skype.
      • Added MTK IMEI Repair over CDC Port.(useful on vivo phones & other which can
        enable port without root.)
        Note: for vivo v5 please use *#558# to enable cdc port.
        Note2: We will add next days CDC port via bootrom in next coming updates.
      • Added External HWID loading methods plan and calculated via at terminal.
    • Improvements:
      • IMEI Cert adb for many models.
      • IMEI Cert adb hw sec key will be always saved.
      • Samsung SPD msl reset.
      • Samsung SPD Unlock.
      • Samsung Exynos unlock on MSL reset.
      • HTC sprint unlock..
    • Key benefits for Motorola ADB Enable:
      • You don't need to buy or use any motorola cracked or paid software.
      • You don't need to setup unknown software,dlls.
      • You can remove frp with GCPro no need any external tool.
      • Very easy & simple just 2 click.
    Strongly recommend to use latest version.
    NO PRO.
    NO PACK.
    NO EVERY YEAR FEE..
    NO ACTIVATION..
    Do you feel it ?
    Do you feel it ?
    Feel The Difference With GCPro.
    Soon all copy paster will start there job.. again remember only GCPro you will always on top.
    Download Links:
    link1= https://mega.nz/#F!1pxHgTBA!P7owR-MlJxD-r0_N6o0xWQ
    link2= https://drive.google.com/folderview?...FE&usp=sharing
    link3= http://www.4shared.com/folder/3Ob62NhG/GCPROTEAM.html
    link4= https://www.dropbox.com/sh/w9gdsem09...Upj32aEVa?dl=0
    link5= https://www.mediafire.com/folder/kzd5v0z4fecn7/GCPROKEY
    Jan 2007
    GcProKey Update51 SAM SPD 2016 models W/O Cert & Sam exynos code read W/O root & more
    GcPro Total update count 51 release date 01-05-2017
    GCPRO GSMTOOL V1.0.0.0045 released.
    • What's New:
      • Added:
        • Samsung Exynos/shannon
          • SS308
          • SS310
          • SS315
          • SS333
          • SS335
          • code read without ROOT.
            Note:baseband need to be older then QAx or use combination modem.
      • Samsung SPD IMEI Repair without certs,both 2015 and 2016 models supported.
        • ROOT NEED beta
          Note: we supported many baseband still if software say unsupported baseband send us backup.
      • Samsung Korean models call me fix via adb format.
        • ADB + ROOT or TWRP or CWM need.
          • beta
            Note:all data will be lost. use adb format and it will fix call me too.
      • OnePlus3 and 3T frp remove in fastboot.
        Note2: Android tab press FRP_Remove (F.BOOT) when ask for OnePlus pres YES
        Note2: It will work on bootlocked phones too,May not work if os is too latest.you can downgrade then reset.
    • Improvements:
      • Patch cert.
      • SS308 support for models J320A,G550FY code read,adb unlock,cert write adb etc
      • imeicert adb security key reading.
      • Exynos key save format.
    • Strongly recommend to use latest version.
      NO PRO.
      NO PACK.
      NO EVERY YEAR FEE..
      NO ACTIVATION..
      Do you feel it ?
      Do you feel it ?
    Jan 2007
    GcProKey Update 52 [LG Sprint 7.x Supported,Samsung S550TL Supported] [09-05-2017]
    GcPro Total update count 52 release date 09-05-2017
    GCPROGSMTOOL V1.0.0.0046 released.
    • What's New:
      • Added
        • World's First Samsung SM-S550TL Sim unlock via exynos unlock
          • With no Root.
        • World's First Samsung SM-S550TL Sim unlock via adb_unlock..
          • Need Root .
        • World's First LG Sprint with Android OS 7.x sim unlock support
          • With no Root.
            Note: Including debarring apn enable etc.
    • Improvements:
      • SS308 support for STL550 and others with same security.
      • SS308 support for code read.
      • MSL Unlock USB codes was not reset.
      • Exynos unlock.
    Strongly recommend to use this version for all your task...
    NO PRO.
    NO PACK.
    NO EVERY YEAR FEE..
    NO ACTIVATION..
    AGAIN REMEMBER ONLY GCPRO YOU WILL ALWAYS ON TOP.
    Do you feel it ?
    Do you feel it ?
    Grab it while its HOT..
    Soon all Copy Paster will start there job.. Some of them Already Started Too
    Jan 2007
    GcPro Total update count 53 release date 18-05-2017
    GCPROGSMTOOL V1.0.0.0047 released.
    • What's New:
      • Improvements:
        • ADB related function return fail even after success.
        • Card related issue with errors on some functions.
      NO PRO.
      NO PACK.
      NO EVERY YEAR FEE..
      NO ACTIVATION..
    • Do you feel it ?
      Do you feel it ?
      Grab it while its HOT....
    Jan 2007
    GcProKey Update54 [World exclusive J727P Samsung Sprint unlock supported]17-06-2017
    GcPro Total update count 54 release date 17-06-2017
    GCPROGSMTOOL V1.0.0.0048 released.
    • What's New:
      • Added:
        • Exynos Shannon phones cert read via exynos unlock
          (till QAx basebands.)
          • With no Root.
          Note: Only tool in market support code read & cert read same time..(till QAx basebands.)
        • World's exclusive J727P Samsung sprint new models unlocking support etc.
          Note: Some of you already noticed combination firmware may help you to sim unlock latest firmware without root.
    • Improvements:
      • adb detection process.
      • qcom repair process.
      • NO PRO.
      • NO PACK.
      • NO EVERY YEAR FEE..
      • NO ACTIVATION..
      • AGAIN REMEMBER ONLY GCPRO YOU WILL ALWAYS ON TOP.
    • Do you feel it ?
    • Do you feel it ?
    • Feel The Difference With GCPro.
    • Grab it while its HOT..
    Jan 2007
    GcProKey Update55 [Samsung FRP,Samsung MTK,Samsung QCOM Reset efs, etc][15-08-2017]
    GcPro Total update count 55 release date 15-08-2017
    GCPROGSMTOOL V1.0.0.0049 released.
    • What's New:
      • Added:
        • Samsung FRP_UFS via uart support.
          Note: Please read help-file for steps.
        • Samsung MTK base simlock code read support (use ADB unlock)
          • Need Root
        • Samsung qcom efs reset method (use reset efs Button)
          • without root.
        • MTK new security imei Repair support.
    • Improvements:
      • Improved spd imei repair.
      • MTK imei repair via ADB.
      • Samsung sprint unlock fail on some 6.x androids.
      • ADB methods for unsecured roots.
      • ADB internal functions.
      • All Card Firmware updated to version 2. You many need to update your card with update tool.
        • Card issue on many case..
          • GCPROLGCDMA
          • GCPROZTECDMA
          • GCPROHUAWEICDMA
          • GCPROMULTICDMA
      NO PRO.
      NO PACK.
      NO EVERY YEAR FEE..
      NO ACTIVATION..
    • Do you feel it ?
      Do you feel it ?
    Thành viên mới PHUYENGSM's Avatar
    Dec 2013
    nó báo Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help..
    Job finish
    update không được !!!!
    Jan 2007
    How to update to latest version?
    Hello every one.
    We know you having issue.
    Please go to support download latest update55new.
    Go to updatetool folder open update tool select Update GCPro press do job.
    In case any error contact at skype. do not post here. if you can't use skype use facebook messenger to talk if you can't use both post in activation thread.
    Make sure latest update55new is latest not update55.
    @Update1.
    "Card error fail to start security session....6982"
    Some user face this error due to SCARD CARD SECURITY MANAGER IS BLOCKED(3 WRONG AUTH KEY SENDING) by unknown tools,software or other team which don't know how to update.
    Nothing to worry at present you can ask for restore old version flag in your GCPro via skype or wait till we update to solve such issue...
    Best Regards,
    GCPro_Team
    GCPROKEY
    __________________
    Best Regards
    GCPro_Team
  10. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    CNB_DRT (17-08-2017)
  11. #10
    Jan 2007
    GcProKey Update57 [Samsung MSL over ADB,lots improvements .][11-09-2017]
    ]GcPro Total update count 57 release date 11-09-2017
    GCPROGSMTOOL V1.0.0.0050 released.
    • What's New:
      • Added Samsung MSL send support via adb
        • without root or reflash any combination..
          • (use same option MSL Unlock USB)
            Note 1: Model like s8 or new don't have UART cable yet in market you can use this option to send MSL code and direct unlock.
            Note 2: We do not provide MSL service. MSL16 must be get from other sources,3rd party etc.
    • Improvements:
      • Samsung efs reset for qcom without root.(careful no backup is made because of no root.)
      • Samsung sprint unlock for non rooted 6.x
      • MODGC method should work now on almost qcom old to latest.
      • Samsung repair imei,cert write etc MSL auth issue.
      • Samsung MTK code reader.
      • Samsung bypass knox.
      • ADB handling with some custom root.
      NO PRO.
      NO PACK.
      NO EVERY YEAR FEE..
      NO ACTIVATION..
      Do you feel it ?
      Do you feel it ?
    • Big thanks to all bug hunters who helped to improve GCPro software's.
Hiện có 5 người đang xem bài này . Bao gồm : 0 thành viên và 5 khách
