LG2G Rocker v1.43 - Samsung Infineon S3550 Shark unlock ! ! !
21.06.2010 LG2G Rocker v1.43 released
Whats new
* Added Samsung S3550 Shark (Infineon PMB8810 based) standalone unlock code calculation - World First ! ! !
* Fixed support for KM900, KP500, KS360, GB220 new firmware versions
* Fixed communication with some models
To unlock Samsung S3550 You need to use Micro USB cable !
If You already have installed Infineon USB drivers You just need to use same procedure as for any other LG - KS360 or KP500 for example.
* Start LG2G Rocker
* Select Samsung
* On Drop down list confirm "S3550"
* Press "Connect"
* Connect phone in powered OFF state
* Wait for process to be finished
To enter unlock code, insert not supported sim,and type #0111*CODE#.
Here is sample log from Samsung S3550 unlock code reading:
Code:
Please wait ...
Phone : S3550
Press PowerON button.
Connected to \\.\USB1
Detected : USB PMB8810.
Phone Found. Loading Boot...
Boot-loader is active.
EBL version: xmm2130_INSA_JA1_10.2_M1S1 10..2
Boot type 0xBB
Flash: Intel PF38F6070M0Y1CE 128MB
CFI stage 2.
EEPROM Imei : 359381030223250
Please wait for calc codes.
Done in 0:03:24 sec.
Code #1: 00000000
SP code : 79643017
Code #3: 00000000
Code #4: 00000000
Unfreeze code : 29164806
Please download and install "LG2G_Rocker_v1.43.exe" from Rocker Dongle support.
Sharing files from support area is NOT ALLOWED ! Users who share files will be banned, and dongles blacklisted !
Enjoy using Rocker Dongle !
