GTSAccess 1.34 BB5 ASK/RPL SERVICE
Release notes of GTSAccess 1.34
Run GriffinSAccess.exe
select login method : USER NAME
ENTER YOUR USER NAME AND PASS FOR GT SERVER
click on CheckAccount
very important is to have this 2 services:
NK_BB5_PM_AUTH 0 credits
NK_BB5_CERT_REST 40 credits
Is possible some special (limited) accounts to not have this 2 services
How to use GTSAccess 1.34 for BB5 ASK/RPL
Click on send file(s) select ask file which was read with MT box( we do not support other product formats)
you will see this:
Server IP: 213.16.42.125, Box_SNyour user name )
Connect... Resp: o/0110/hello there
Login...OK, available count xxx;
busy, waiting...
e/0/accepted;
accepted ; means your file is good and is recieved for calculation from server
So now neade to wait from 1 hr to 24 hr ( usual time 15 mins )
If for some reason the RPL file is not computed within 72h, the ASK will be deleted from server,and the credits will be restored to the account. This also means that maximum calculation time for RPLs is 72h.
It should be around 20 min when normal operation.
How to get your rpl:
Again need to click on send file select same file and you can see 2 variants:
1.
busy, waiting...
e/0/pending;
pending; means your ask file is still under calculation and need to check later
2.
busy, waiting...
Data Received!
File <C:\xxxfolder\35xx0300x4xx0x7.RPL> Created!
So this is your RPL file now can use MTbox to write in phone.
Please don't send ASK files from EMPTY BOARDS. They will not be computed.
!!!! VERY IMPORTANT !!!!
ALL WE KNOW FOR PROBLEMS WHIT BAD QUALITY SERVICE CABLES.
ON THIS CASE IS CRITICAL PHONE TO BE IN LOCAL OR TEST MODE after RESTART from certificate write.
so please check this link:
http://forum.gsmhosting.com/vbb/show...58&postcount=6
Problem is also 10 to 8 pin adapter cable connectors have very poor contact of GND and this come a big problem.
(we already start producing new type adapter cable)
Some times is need to push hard RG45 to adapter to be able to have any communication.
So if you not see this:
Simlock send - SUCCESSFULL!!!
SuperDongle send - SUCCESSFULL!!!
Simple check YOUR cable connection befor make any posting on forums.
BRGT
đây lf ban update mới nhất
bản 1.34 anh tai nói ở trên mình up lên cho mọi người luôn
