mx-box cần ace dúp
cái box của em chạy nó cứ báo lỗi các bác xem qua em cái.chạy 2 con máy quang tèo hết.huhu
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0854FE1
Using device: HTI, FW ver: 00.24, SN: 00003FFC
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
Performing Flash Authentication ...ASIC type: 2
UEM Imei: Empty
Flash Imei: 35867001197530
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\_BACK.rpl"
Processing MCU file: rh93_07.020
[DCT4,DCT4 ALGORITHM] size: 1.89 MB
Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
Performing Flash Authentication ...Area [01000000-0100FFFF] erased in 0.516 s
Area [01010000-013BFFFF] erased in 31.719 s
Area [013C0000-013EFFFF] erased in 2.125 s
Area [017C0000-017EFFFF] erased in 0.187 s
Area [01FC0000-01FEFFFF] erased in 0.203 s
Flash programming ...
Programming completed in 18.266 s
File Processed in 1 min 4.562 s
Processing CNT file: rh930_nai7.02md
[DCT4,DCT4 ALGORITHM] size: 163.08 KB
Performing Flash Authentication ...Area [01380000-013BFFFF] erased in 2.375 s
Programming completed in 1.766 s
Content extract fail, continue anyway ...
File Processed in 57.500 s
Processing PPM file: rh93_07.02md
[DCT4,DCT4 ALGORITHM] size: 1.50 MB
Performing Flash Authentication ...Area [011E0000-011EFFFF] erased in 0.562 s
Area [011F0000-0137FFFF] erased in 13.219 s
Programming completed in 14.500 s
File Processed in 39.891 s
Total time for flashing process(boot+erase+write) was 2 min 41.953 s
máy bạn ko lên nguồn
ko đồng bộ được
nó báo lỗi ở đoạn nạp xong file bộ sưu tập
xóa full rồi nạp lại xem sao nhé
vâng để em thử
nhưng sao hom qua em chạy con 1202 nó củng y bệnh con này.liệu có lỗi box hay cài đặt j ko bác
có thể nhưng ít
cứ test đi xem sao
mà phải biết tình trạng máy ban đầu nhé,nếu đang chết mà chạy báo thế là bình thường mà
