nokia 525 treo nokia flash not ok
em nhận cây 525 ( rm-998 ) treo nokia, em dùng atf flash báo done nhưng vẫn treo
bác nào gặp qua xin chỉ giáo ạ
log atf :
Windows Phone 8/8.1/10 Flashing Started
Loading Flash Files Please Wait...
[DEAD BOOT REPAIR via USB is SUPPORTED]
Windows Phone 8/8.1/10 Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Connect Phone to the USB Port
2. Press and Hold the VOLUME DOWN and POWER Buttons
3. Wait until the Phone Vibrates Shortly...
4. Stop Pressing the Buttons...
If the Phone is DEAD BOOT
2. Install Correct Drivers:
"Nokia Emergency Connectivity" Located at:
D:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\
Nokia Phone Info Mode Initiated...
Please wait upto 15 Seconds for SW Reset
IMEI: 359182056867941
Version: 1.1.1.3
Product Code: 059V486
Module Code: 0205952
Continuing Previous Boot...
Please wait upto 30 Seconds for Boot Re-entry
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00E74000
Block ID 0x05 : Nokia.MSM8227.P6137.1.2
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100130000
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode :
Query Flash App Information...
Flash App Information: 02010F011C00
UEFI App: FLASH APP
Flash App Protocol Version: 1.15
Flash App Implementation Version: 1.28
Query ROOT KEY HASH...
ROOT_KEY_HASH: 25C0C84AECBD154F817825B24D4EB4BCF5E606E66228BD6A77 997ACC54710C5E
Query PUBLIC ID...
PUBLIC_ID: 2DA97E7CDD3A53B043443F3BF593E2841F50E16C
Query eMMC Info...
EMMC Manufacture ID: HYNIX
EMMC Product SN : 00E1C7A7
EMMC_SIZE: 8 Gigabytes
Query Battery Charge Status...
BATTERY CHARGE_STATUS: 33%
Sending Image Signatures...
Image Signatures Accepted!
Erasing Data Partition...
Data Partition Erased Successfully
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:02:50
