Help me w580 unlock
Chào các cao thủ ạ. hôm nay em gặp con Sony w580 mở mạng mà em đẫ unlock nhưng không được bỏ sim vào vẫn báo inset sim correch,hichic:confused:
Còn đây là log của nó ạ. Các cao thủ chỉ giáo dùm em
v0.914020/UNI
CARD SERIAL: 00084333
Loaded 51 flash descriptors
SERVER SUPPORT ENABLED.
ALTERNATIVE SECURITY BYPASS ENABLED.
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
Flash ID check:2019
Flash props sent ok
OTP LOCKED:1 CID:51 PAF:1 IMEI:35344702148733 CERT:RED
FLASH CID:52 COLOR:RED
Model:W580i
Brand:Generic Trade
MAPP CXC article: R8BE001 prgCXC1123476_CHINA_LA
MAPP CXC version: R8BE001
Language Package:APAC
CDA article: CDA102239/43
CDA version: R15A
Default article: cxc1123364
Default version: R8BE001
Chổ này em thấy thiếu chữ Networt LOCKET:confused:
Operator: 000-00
RESTORATION FILE NOT PRESENT
"R8BE001_CXC1123476_CHINA_LA"
YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK
SECURITY UNITS BACKUP CREATED.
Elapsed:5 secs.
Abort all operations.
phone pre-boot failed,possible RECOVERY needed.
Elapsed:3 secs.
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:2019
Flash props sent ok
CID52 BYPASS PROCEDURE STARTED
Processing part1...
Processing part2...
Processing part3....
Flash ID check:2019
Flash props sent ok
REMOVE CABLE FROM PHONE
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
HOLD "C" BUTTON AND ATTACH PHONE
CID52 BYPASS PROCEDURE FINISHED
bypassing security...
Speed:921600
Trying to launch embedded bootloader...
Embedded flashloader:
DB2020_PRELOADER_FOR_SETOOL2
Flash ID check:2019
Flash props sent ok
writing D:\SOFTWARE\Flash File\SETOOL\W580\R8BE001\R8BE001_1123476_CHINA_LA. ssw
CURRENT FLASH FILE CID:52
SSW uses complete hash, hash len is:9200
Will flash 460 blocks...
SSW loading returns:0
full sig complete.
USERCODE RESET TO "0000"
Searching...
Firmware lock check determined.
Elapsed:634 secs.
Bạn đọc chỗ này & làm theo hướng dẫn để unlock,thân!
