6303 cần giúp gấp
máy bị contacssevice.đây là log
MXKEY Serial: [FT SCR2000 0] - C08148CE
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.12920(08-10-2011)
Processing MCU file: rm443__10.10.mcusw
[BB5,BB5 ALGORITHM] size: 24.67 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 4135E9A
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
CMT EM0 ID: 00000295
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 26400115C94C7E560492044C70331472CDA1FF4D
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 1B86B587
Verifying communication to device OK.
Erase size: 28.25 MB
CMT NOR area [00000000-0001FFFF] erased in 0.515 s
CMT NOR area [00040000-0005FFFF] erased in 0.609 s
CMT NOR area [00060000-0007FFFF] erased in 0.641 s
CMT NOR area [00080000-0015FFFF] erased in 4.484 s
CMT NOR area [00160000-0023FFFF] erased in 4.157 s
CMT NOR area [01740000-0191FFFF] erased in 9.516 s
CMT NOR area [00240000-0173FFFF] erased in 1 min 44.219 s
CMT NOR area [022E0000-0261FFFF] erased in 16.187 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 (RAP Certificate 140 v.1) sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT ISA+DYNSW block sent
Programming completed in 1 min 31.578 s
Processing PPM file: rm443__10.10.ppm_v
[BB5,BB5 ALGORITHM] size: 7.29 MB
Erase size: 9.75 MB
CMT NOR area [01920000-022DFFFF] erased in 47.609 s
Programming completed in 25.312 s
Processing CNT file: rm443__10.10.image_v_kh_matt_black
[BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 25.62 MB
CMT NOR area [02620000-029BFFFF] erased in 24.718 s
CMT NOR area [029C0000-03FBFFFF] erased in 2 min 19.734 s
Programming completed in 47.984 s
Total time for flashing process(boot+erase+write) was 9 min 2.547 s
Waiting for device boot up ...
Device found: nmwcdc\Nokia 6303 classic USB Phonet, PORT_ID: 35ADF263
Phone Type: RM-443 (Nokia 6303 classic)
SW Version: V 10.10 18-11-09 RM-443 (c) Nokia
Imei plain: 35319903348578-3
Product Code: 0569168
Battery voltage: 3871 mV, current: 92 mA
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
e nghĩ là phải thay cặp.có bác nào cách giải quyết hay xin cho ý kiến
SIMLOCK_TEST failed! rồi.
thay cặp khác còn ko gởi vào anh Xuân unlock e nó đi anh ơi.nhưng giá cao đấy...
nếu bạn có backup đc vùng simlock 120 thì write vào = ok nếu ko chỉ còn cách thay cặp hoặc liên hệ ADMIN để unlock sl3
máy của người quen,chỉ tắt máy đi bật lên là bị.ko backup được gì.ae nào biết cho xin cái giá
chỉ có nước như 2 anh ý mách bạn thui!
