C2-02.1 RM-693 unlock ok (giải pháp)
Dùng bestool read has rồi đem qua PC khủng quay code =>nhập code ok nhưng lắp sim ko có sóng
Dùng atf convert qua C2-02 RM-692 => write pm rm-692 done lúc này có sóng nhưng chỉ có 1 vạch
Thay tiếp lọc 8 chân ( lọc dòng chip xgold) sóng đăng đét => lum gạo
Anh em gặp cứ múc
Log ATF
Code:
Number of Image Files: 3
Processing Image File :
rm692__06.96.mcusw
rm692__06.96.ppm_h
rm692__06.96.image_h_059D3C3-v2
[]: Found 1 active devices.
[Nokia C2-02 USB Phonet]: Opening Connection
[Nokia C2-02 USB Phonet]: Port opened OK!
SW: V 06.96 09-09-11 RM-693 (c) Nokia
IMEI: 012630003634003
START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
FULL PM Backup Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\012630003634003\USB_FULL_BACKUP_V 06.96 09-09-11 RM-693 (c) Nokia_012630003634003__25300.pm
Reading battery value : 3700 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Sections : 04
Current File : rm692__06.96.mcusw
Compile Name: rm692__06.96.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 29363592 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 20BF
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7AB2
Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 227D
Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41DBFFFE
Start Erasing...
Block Erase Done...
Data Size: 28049408 bytes
Data Checksum: 745D
Data Verification Successful...
Sections : 01
Current File : rm692__06.96.ppm_h
Compile Name: package_h.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 4043120 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41DC0000~0x424BFFFE
Start Erasing...
Block Erase Done...
Data Size: 4039776 bytes
Data Checksum: A3BE
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm692__06.96.image_h_059D3C3-v2
Compile Name: package_h_059D3C3.image.fls
Image Type : CONTENT Package
Data Size : 12324112 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x424C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 12320768 bytes
Data Checksum: DB0C
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:08:22
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 06.96 09-09-11 RM-693 (c) Nokia
IMEI Plain : 012630003634003
IMEI Spare : A012630003634000
IMEI SV : 30126300036340005F
Phone Model: KÉ C2-02
Category : Phone
Phone Type : RM-693
Extended Phone Information
Product Serial Number: 491E76AAH
Product Code : 059L6L4
Module Code : 0204676
Basic Production Code: 0593196
Long Production SN : 0
PPM SW Version : V 06.96 09-09-11 RM-692 (c) Nokia H
BT MCM Version : 19b5-22012
MCU SW Version : V 06.96 09-09-11 RM-693 (c) Nokia
HW Version : 1500
RFIC Version : Dummy RFIC version
LCD Version : TPO
FWID Version : iV 06.96 09-09-11 RM-693 (c) Nokia V 06.96 09-09-11 RM-692 (c) Nokia H 059L6L4 001
Content Pack Version : Content: h_059D3C3 V 06.96 09-09-11 RM-692 (c) Nokia
Bluetooth ID : 28:D1:AF:9E:FD:EC
CS Type : GSM850, GSM1900
********** SIMLOCK INFO **********
CONFIG_DATA : 3027200000000000
PROFILE_BITS : 800000000003000B
ASIC : 11
PROVIDER : Rorges Communications;Canada [GSM]
Unable to completely read SL Table..
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 06150123
DCC Ver: 007025
Status : OK
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
Selected PM File: C:\Documents and Settings\Admin\Desktop\New Folder\RM-692 C2-02_357005044168910_0_400.pm
Start Uploading PM...
MCU: V 06.96 09-09-11 RM-693 (c) Nokia
Model : K1 C2-02
Error: USB BULK WRITE FAILED
HW Version : 1500
LCD Version : TPO
ASIC : 11
ST_SIMLOCK_TEST : PASSED
ST_LCD_TEST : PASSED
MASTER_CODE : 4622005770
PHONE_MODE : TEST
DCC ID : 06150123
DCC Ver: 007025
Status : OK
Field : 3 Sub : 0 Byte(s): 2 - Ok
Field : 4 Sub : 1 Byte(s): 800 - Ok
Field : 4 Sub : 3 Byte(s): 10 - Ok
Field : 4 Sub : 4 Byte(s): 8 - Ok
Field : 4 Sub : 5 Byte(s): 8 - Ok
Field : 4 Sub : 6 Byte(s): 8 - Ok
Field : 4 Sub : 9 Byte(s): 5 - Ok
Field : 4 Sub : 18 Byte(s): 80 - Ok
Field : 4 Sub : 19 Byte(s): 4 - Ok
Field : 4 Sub : 26 Byte(s): 132 - Ok
Field : 4 Sub : 28 Byte(s): 2 - Ok
Field : 8 Sub : 0 Byte(s): 2 - Ok
Field : 8 Sub : 1 Byte(s): 16 - Ok
Field : 8 Sub : 2 Byte(s): 16 - Ok
Field : 8 Sub : 3 Byte(s): 128 - Ok
Field : 8 Sub : 4 Byte(s): 128 - Ok
Field : 8 Sub : 5 Byte(s): 8 - Ok
Field : 8 Sub : 7 Byte(s): 4 - Ok
Field : 8 Sub : 8 Byte(s): 8 - Ok
Field : 8 Sub : 9 Byte(s): 8 - Ok
Field : 8 Sub : 10 Byte(s): 32 - Ok
Field : 8 Sub : 11 Byte(s): 4 - Ok
Field : 8 Sub : 12 Byte(s): 4 - Ok
Field : 11 Sub : 0 Byte(s): 4 - Ok
Field : 11 Sub : 1 Byte(s): 4 - Ok
Field : 11 Sub : 2 Byte(s): 4 - Ok
Field : 11 Sub : 3 Byte(s): 4 - Ok
Field : 11 Sub : 4 Byte(s): 241 - Ok
Field : 13 Sub : 0 Byte(s): 1 - Ok
Field : 13 Sub : 1 Byte(s): 2 - Ok
Field : 13 Sub : 2 Byte(s): 1 - Ok
Field : 13 Sub : 3 Byte(s): 2 - Ok
Field : 13 Sub : 4 Byte(s): 1 - Ok
Field : 13 Sub : 5 Byte(s): 1 - Ok
Field : 13 Sub : 6 Byte(s): 1 - Ok
Field : 13 Sub : 7 Byte(s): 1 - Ok
Field : 13 Sub : 8 Byte(s): 2 - Ok
Field : 13 Sub : 9 Byte(s): 1 - Ok
Field : 13 Sub : 10 Byte(s): 1 - Ok
Field : 13 Sub : 11 Byte(s): 48 - Ok
Field : 13 Sub : 12 Byte(s): 4 - Ok
Field : 13 Sub : 13 Byte(s): 1 - Ok
Field : 13 Sub : 14 Byte(s): 1 - Ok
Field : 13 Sub : 15 Byte(s): 886 - Ok
Field : 13 Sub : 16 Byte(s): 2 - Ok
Field : 13 Sub : 17 Byte(s): 1 - Ok
Field : 13 Sub : 18 Byte(s): 1 - Ok
Field : 13 Sub : 19 Byte(s): 8 - Ok
Field : 13 Sub : 20 Byte(s): 1 - Ok
Field : 13 Sub : 21 Byte(s): 1 - Ok
Field : 13 Sub : 22 Byte(s): 1 - Ok
Field : 13 Sub : 23 Byte(s): 1 - Ok
Field : 13 Sub : 24 Byte(s): 1 - Ok
Field : 13 Sub : 25 Byte(s): 2 - Ok
Field : 13 Sub : 26 Byte(s): 1 - Ok
Field : 13 Sub : 27 Byte(s): 1 - Ok
Field : 13 Sub : 28 Byte(s): 1 - Ok
Field : 13 Sub : 29 Byte(s): 1 - Ok
Field : 13 Sub : 30 Byte(s): 1 - Ok
Field : 13 Sub : 31 Byte(s): 1 - Ok
Field : 13 Sub : 32 Byte(s): 1 - Ok
Field : 13 Sub : 33 Byte(s): 1 - Ok
Field : 13 Sub : 34 Byte(s): 1 - Ok
Field : 13 Sub : 35 Byte(s): 1 - Ok
Field : 13 Sub : 36 Byte(s): 1 - Ok
Field : 13 Sub : 37 Byte(s): 4 - Ok
Field : 13 Sub : 38 Byte(s): 1 - Ok
Field : 13 Sub : 39 Byte(s): 1 - Ok
Field : 13 Sub : 40 Byte(s): 1 - Ok
Field : 13 Sub : 41 Byte(s): 1 - Ok
Field : 13 Sub : 42 Byte(s): 4 - Ok
Field : 13 Sub : 43 Byte(s): 4 - Ok
Field : 13 Sub : 44 Byte(s): 1 - Ok
Field : 13 Sub : 45 Byte(s): 4 - Ok
Field : 13 Sub : 46 Byte(s): 4 - Ok
Field : 13 Sub : 47 Byte(s): 1 - Ok
Field : 13 Sub : 48 Byte(s): 4 - Ok
Field : 13 Sub : 49 Byte(s): 1 - Ok
Field : 13 Sub : 50 Byte(s): 1 - Ok
Field : 13 Sub : 51 Byte(s): 1 - Ok
Field : 13 Sub : 52 Byte(s): 2 - Ok
Field : 13 Sub : 53 Byte(s): 4 - Ok
Field : 13 Sub : 54 Byte(s): 4 - Ok
Field : 13 Sub : 55 Byte(s): 1 - Ok
Field : 13 Sub : 56 Byte(s): 1 - Ok
Field : 13 Sub : 57 Byte(s): 1 - Ok
Field : 13 Sub : 58 Byte(s): 2 - Ok
Field : 13 Sub : 59 Byte(s): 1 - Ok
Field : 13 Sub : 60 Byte(s): 4 - Ok
Field : 13 Sub : 61 Byte(s): 4 - Ok
Field : 13 Sub : 62 Byte(s): 1 - Ok
Field : 13 Sub : 63 Byte(s): 4 - Ok
Field : 13 Sub : 64 Byte(s): 4 - Ok
Field : 13 Sub : 65 Byte(s): 1 - Ok
Field : 13 Sub : 66 Byte(s): 4 - Ok
Field : 13 Sub : 67 Byte(s): 4 - Ok
Field : 13 Sub : 68 Byte(s): 1 - Ok
Field : 13 Sub : 69 Byte(s): 1 - Ok
Field : 13 Sub : 70 Byte(s): 1 - Ok
Field : 13 Sub : 71 Byte(s): 4 - Ok
Field : 13 Sub : 72 Byte(s): 4 - Ok
Field : 13 Sub : 73 Byte(s): 1 - Ok
Field : 13 Sub : 74 Byte(s): 4 - Ok
Field : 13 Sub : 75 Byte(s): 2 - Ok
Field : 13 Sub : 76 Byte(s): 2 - Ok
Field : 13 Sub : 77 Byte(s): 2 - Ok
Field : 13 Sub : 78 Byte(s): 1 - Ok
Field : 13 Sub : 79 Byte(s): 1 - Ok
Field : 13 Sub : 80 Byte(s): 1 - Ok
Field : 13 Sub : 81 Byte(s): 1 - Ok
Field : 13 Sub : 82 Byte(s): 1 - Ok
Field : 13 Sub : 83 Byte(s): 2 - Ok
Field : 13 Sub : 84 Byte(s): 1 - Ok
Field : 13 Sub : 85 Byte(s): 4 - Ok
Field : 13 Sub : 86 Byte(s): 4 - Ok
Field : 13 Sub : 87 Byte(s): 2 - Ok
Field : 13 Sub : 88 Byte(s): 1 - Ok
Field : 13 Sub : 89 Byte(s): 4 - Ok
Field : 13 Sub : 90 Byte(s): 4 - Ok
Field : 13 Sub : 91 Byte(s): 2 - Ok
Field : 13 Sub : 92 Byte(s): 1 - Ok
Field : 13 Sub : 93 Byte(s): 4 - Ok
Field : 13 Sub : 94 Byte(s): 4 - Ok
Field : 13 Sub : 95 Byte(s): 2 - Ok
Field : 13 Sub : 96 Byte(s): 1 - Ok
Field : 13 Sub : 97 Byte(s): 4 - Ok
Field : 13 Sub : 98 Byte(s): 4 - Ok
Field : 13 Sub : 99 Byte(s): 2 - Ok
Field : 13 Sub : 100 Byte(s): 4 - Ok
Field : 13 Sub : 101 Byte(s): 2 - Ok
Field : 13 Sub : 102 Byte(s): 1 - Ok
Field : 13 Sub : 103 Byte(s): 4 - Ok
Field : 13 Sub : 104 Byte(s): 4 - Ok
Field : 13 Sub : 105 Byte(s): 4 - Ok
Field : 13 Sub : 106 Byte(s): 4 - Ok
Field : 13 Sub : 107 Byte(s): 4 - Ok
Field : 13 Sub : 108 Byte(s): 2 - Ok
Field : 13 Sub : 109 Byte(s): 4 - Ok
Field : 13 Sub : 110 Byte(s): 4 - Ok
Field : 13 Sub : 111 Byte(s): 4 - Ok
Field : 13 Sub : 112 Byte(s): 2 - Ok
Field : 13 Sub : 113 Byte(s): 4 - Ok
Field : 13 Sub : 114 Byte(s): 4 - Ok
Field : 13 Sub : 115 Byte(s): 1 - Ok
Field : 13 Sub : 116 Byte(s): 1 - Ok
Field : 13 Sub : 117 Byte(s): 1 - Ok
Field : 13 Sub : 118 Byte(s): 4 - Ok
Field : 13 Sub : 119 Byte(s): 4 - Ok
Field : 13 Sub : 120 Byte(s): 1 - Ok
Field : 13 Sub : 121 Byte(s): 1 - Ok
Field : 13 Sub : 122 Byte(s): 1 - Ok
Field : 13 Sub : 123 Byte(s): 8 - Ok
Field : 13 Sub : 124 Byte(s): 1 - Ok
Field : 13 Sub : 125 Byte(s): 1 - Ok
Field : 13 Sub : 126 Byte(s): 1 - Ok
Field : 13 Sub : 127 Byte(s): 1 - Ok
Field : 13 Sub : 128 Byte(s): 1 - Ok
Field : 13 Sub : 129 Byte(s): 4 - Ok
Field : 13 Sub : 130 Byte(s): 4 - Ok
Field : 13 Sub : 131 Byte(s): 1 - Ok
Field : 13 Sub : 132 Byte(s): 1 - Ok
Field : 13 Sub : 133 Byte(s): 2 - Ok
Field : 13 Sub : 134 Byte(s): 1 - Ok
Field : 13 Sub : 135 Byte(s): 2 - Ok
Field : 13 Sub : 136 Byte(s): 1 - Ok
Field : 13 Sub : 137 Byte(s): 1 - Ok
Field : 13 Sub : 138 Byte(s): 4 - Ok
Field : 13 Sub : 139 Byte(s): 4 - Ok
Field : 13 Sub : 140 Byte(s): 1 - Ok
Field : 13 Sub : 141 Byte(s): 1 - Ok
Field : 13 Sub : 142 Byte(s): 1 - Ok
Field : 13 Sub : 143 Byte(s): 1 - Ok
Field : 13 Sub : 144 Byte(s): 4 - Ok
Field : 13 Sub : 145 Byte(s): 8 - Ok
Field : 13 Sub : 146 Byte(s): 4 - Ok
Field : 13 Sub : 147 Byte(s): 4 - Ok
Field : 13 Sub : 148 Byte(s): 1 - Ok
Field : 13 Sub : 149 Byte(s): 1 - Ok
Field : 13 Sub : 150 Byte(s): 1 - Ok
Field : 13 Sub : 151 Byte(s): 1 - Ok
Field : 13 Sub : 152 Byte(s): 1 - Ok
Field : 13 Sub : 153 Byte(s): 1 - Ok
Field : 13 Sub : 154 Byte(s): 1 - Ok
Field : 13 Sub : 155 Byte(s): 1 - Ok
Field : 13 Sub : 156 Byte(s): 1 - Ok
Field : 13 Sub : 157 Byte(s): 1 - Ok
Field : 13 Sub : 158 Byte(s): 1 - Ok
Field : 13 Sub : 159 Byte(s): 2 - Ok
Field : 13 Sub : 160 Byte(s): 2 - Ok
Field : 13 Sub : 161 Byte(s): 1 - Ok
Field : 13 Sub : 162 Byte(s): 1 - Ok
Field : 13 Sub : 163 Byte(s): 1 - Ok
Field : 13 Sub : 164 Byte(s): 1 - Ok
Field : 13 Sub : 165 Byte(s): 1 - Ok
Field : 13 Sub : 166 Byte(s): 1 - Ok
Field : 42 Sub : 0 Byte(s): 2 - Ok
Field : 42 Sub : 1 Byte(s): 12 - Ok
Field : 42 Sub : 2 Byte(s): 36 - Ok
Field : 42 Sub : 3 Byte(s): 36 - Ok
Field : 42 Sub : 4 Byte(s): 36 - Ok
Field : 42 Sub : 5 Byte(s): 36 - Ok
Field : 42 Sub : 6 Byte(s): 36 - Ok
Field : 42 Sub : 7 Byte(s): 40 - Ok
Field : 42 Sub : 8 Byte(s): 40 - Ok
Field : 42 Sub : 9 Byte(s): 40 - Ok
Field : 42 Sub : 10 Byte(s): 40 - Ok
Field : 42 Sub : 11 Byte(s): 40 - Ok
Field : 42 Sub : 12 Byte(s): 40 - Ok
Field : 42 Sub : 13 Byte(s): 40 - Ok
Field : 42 Sub : 14 Byte(s): 40 - Ok
Field : 42 Sub : 15 Byte(s): 40 - Ok
Field : 42 Sub : 16 Byte(s): 40 - Ok
Field : 42 Sub : 17 Byte(s): 40 - Ok
Field : 42 Sub : 18 Byte(s): 40 - Ok
Field : 42 Sub : 19 Byte(s): 40 - Ok
Field : 42 Sub : 20 Byte(s): 40 - Ok
Field : 42 Sub : 21 Byte(s): 40 - Ok
Field : 42 Sub : 22 Byte(s): 40 - Ok
Field : 42 Sub : 23 Byte(s): 40 - Ok
Field : 42 Sub : 24 Byte(s): 40 - Ok
Field : 42 Sub : 25 Byte(s): 40 - Ok
Field : 42 Sub : 26 Byte(s): 40 - Ok
Field : 54 Sub : 0 Byte(s): 2 - Ok
Field : 54 Sub : 2 Byte(s): 24 - Ok
Field : 96 Sub : 0 Byte(s): 2 - Ok
Field : 96 Sub : 1 Byte(s): 20 - Ok
Field : 107 Sub : 0 Byte(s): 21 - Ok
Field : 107 Sub : 1 Byte(s): 89 - Ok
Field : 107 Sub : 2 Byte(s): 69 - Ok
Field : 107 Sub : 3 Byte(s): 70 - Ok
Field : 107 Sub : 24 Byte(s): 88 - Ok
Field : 107 Sub : 25 Byte(s): 136 - Ok
Field : 107 Sub : 26 Byte(s): 12 - Ok
Field : 116 Sub : 0 Byte(s): 2 - Ok
Field : 116 Sub : 1 Byte(s): 12 - Ok
Field : 116 Sub : 2 Byte(s): 36 - Ok
Field : 116 Sub : 3 Byte(s): 36 - Ok
Field : 116 Sub : 4 Byte(s): 36 - Ok
Field : 116 Sub : 5 Byte(s): 36 - Ok
Field : 116 Sub : 6 Byte(s): 36 - Ok
Field : 116 Sub : 7 Byte(s): 40 - Ok
Field : 116 Sub : 8 Byte(s): 40 - Ok
Field : 116 Sub : 9 Byte(s): 40 - Ok
Field : 116 Sub : 10 Byte(s): 40 - Ok
Field : 116 Sub : 11 Byte(s): 40 - Ok
Field : 116 Sub : 12 Byte(s): 40 - Ok
Field : 116 Sub : 13 Byte(s): 40 - Ok
Field : 116 Sub : 14 Byte(s): 40 - Ok
Field : 116 Sub : 15 Byte(s): 40 - Ok
Field : 116 Sub : 16 Byte(s): 40 - Ok
Field : 117 Sub : 5 Byte(s): 10 - Ok
Field : 117 Sub : 6 Byte(s): 8 - Ok
Field : 117 Sub : 16 Byte(s): 62 - Ok
Field : 153 Sub : 0 Byte(s): 68 - Ok
Field : 153 Sub : 1 Byte(s): 68 - Ok
Field : 153 Sub : 2 Byte(s): 68 - Ok
Field : 153 Sub : 3 Byte(s): 68 - Ok
Field : 153 Sub : 4 Byte(s): 68 - Ok
Field : 153 Sub : 5 Byte(s): 68 - Ok
Field : 163 Sub : 0 Byte(s): 8 - Ok
Field : 193 Sub : 2 Byte(s): 8 - Ok
Field : 193 Sub : 3 Byte(s): 32 - Ok
Field : 193 Sub : 4 Byte(s): 32 - Ok
Field : 193 Sub : 9 Byte(s): 64 - Ok
Field : 202 Sub : 0 Byte(s): 1 - Ok
Field : 202 Sub : 1 Byte(s): 780 - Ok
Field : 217 Sub : 0 Byte(s): 32 - Ok
Field : 218 Sub : 0 Byte(s): 2 - Ok
Field : 238 Sub : 1 Byte(s): 1 - Ok
Field : 239 Sub : 0 Byte(s): 2 - Ok
Field : 239 Sub : 1 Byte(s): 6911 - Ok
Field : 239 Sub : 2 Byte(s): 6911 - Ok
Field : 239 Sub : 3 Byte(s): 6911 - Ok
Field : 239 Sub : 4 Byte(s): 6911 - Ok
Field : 301 Sub : 0 Byte(s): 2 - Ok
Field : 301 Sub : 1 Byte(s): 12 - Ok
Field : 301 Sub : 2 Byte(s): 36 - Ok
Field : 301 Sub : 3 Byte(s): 36 - Ok
Field : 301 Sub : 4 Byte(s): 36 - Ok
Field : 301 Sub : 5 Byte(s): 36 - Ok
Field : 301 Sub : 6 Byte(s): 36 - Ok
Field : 301 Sub : 7 Byte(s): 40 - Ok
Field : 301 Sub : 8 Byte(s): 40 - Ok
Field : 301 Sub : 9 Byte(s): 40 - Ok
Field : 301 Sub : 10 Byte(s): 40 - Ok
Field : 301 Sub : 11 Byte(s): 40 - Ok
Field : 301 Sub : 12 Byte(s): 40 - Ok
Field : 301 Sub : 13 Byte(s): 40 - Ok
Field : 301 Sub : 14 Byte(s): 40 - Ok
Field : 301 Sub : 15 Byte(s): 40 - Ok
Field : 301 Sub : 16 Byte(s): 40 - Ok
Field : 308 Sub : 0 Byte(s): 1 - Ok
Field : 308 Sub : 3 Byte(s): 1 - Ok
Field : 308 Sub : 4 Byte(s): 1 - Ok
Field : 308 Sub : 5 Byte(s): 10 - Ok
Field : 308 Sub : 6 Byte(s): 1 - Ok
Field : 308 Sub : 7 Byte(s): 1 - Ok
Field : 308 Sub : 8 Byte(s): 1 - Ok
Field : 308 Sub : 9 Byte(s): 40 - Ok
Field : 322 Sub : 0 Byte(s): 1 - Ok
Field : 339 Sub : 0 Byte(s): 511 - Ok
Field : 339 Sub : 1 Byte(s): 511 - Ok
Field : 341 Sub : 0 Byte(s): 1 - Ok
Field : 341 Sub : 3 Byte(s): 4 - Ok
Field : 341 Sub : 4 Byte(s): 4394 - Ok
Field : 354 Sub : 0 Byte(s): 15 - Ok
Field : 355 Sub : 0 Byte(s): 19071 - Ok
Field : 362 Sub : 0 Byte(s): 1 - Ok
Field : 362 Sub : 1 Byte(s): 120 - Ok
Field : 364 Sub : 0 Byte(s): 2 - Ok
Field : 364 Sub : 1 Byte(s): 12 - Ok
Field : 364 Sub : 2 Byte(s): 36 - Ok
Field : 364 Sub : 3 Byte(s): 36 - Ok
Field : 364 Sub : 4 Byte(s): 36 - Ok
Field : 364 Sub : 5 Byte(s): 36 - Ok
Field : 364 Sub : 6 Byte(s): 36 - Ok
Field : 364 Sub : 7 Byte(s): 40 - Ok
Field : 364 Sub : 8 Byte(s): 40 - Ok
Field : 364 Sub : 9 Byte(s): 40 - Ok
Field : 364 Sub : 10 Byte(s): 40 - Ok
Field : 364 Sub : 11 Byte(s): 40 - Ok
Field : 364 Sub : 12 Byte(s): 40 - Ok
Field : 364 Sub : 13 Byte(s): 40 - Ok
Field : 364 Sub : 14 Byte(s): 40 - Ok
Field : 364 Sub : 15 Byte(s): 40 - Ok
Field : 364 Sub : 16 Byte(s): 40 - Ok
Field : 364 Sub : 17 Byte(s): 40 - Ok
Field : 364 Sub : 18 Byte(s): 40 - Ok
Field : 364 Sub : 19 Byte(s): 40 - Ok
Field : 364 Sub : 20 Byte(s): 40 - Ok
Field : 364 Sub : 21 Byte(s): 40 - Ok
Field : 364 Sub : 22 Byte(s): 40 - Ok
Field : 364 Sub : 23 Byte(s): 40 - Ok
Field : 364 Sub : 24 Byte(s): 40 - Ok
Field : 364 Sub : 25 Byte(s): 40 - Ok
Field : 364 Sub : 26 Byte(s): 40 - Ok
Field : 365 Sub : 0 Byte(s): 2 - Ok
Field : 365 Sub : 1 Byte(s): 12 - Ok
Field : 365 Sub : 2 Byte(s): 36 - Ok
Field : 365 Sub : 3 Byte(s): 36 - Ok
Field : 365 Sub : 4 Byte(s): 36 - Ok
Field : 365 Sub : 5 Byte(s): 36 - Ok
Field : 365 Sub : 6 Byte(s): 36 - Ok
Field : 365 Sub : 7 Byte(s): 40 - Ok
Field : 365 Sub : 8 Byte(s): 40 - Ok
Field : 365 Sub : 9 Byte(s): 40 - Ok
Field : 365 Sub : 10 Byte(s): 40 - Ok
Field : 365 Sub : 11 Byte(s): 40 - Ok
Field : 365 Sub : 12 Byte(s): 40 - Ok
Field : 365 Sub : 13 Byte(s): 40 - Ok
Field : 365 Sub : 14 Byte(s): 40 - Ok
Field : 365 Sub : 15 Byte(s): 40 - Ok
Field : 365 Sub : 16 Byte(s): 40 - Ok
Field : 372 Sub : 0 Byte(s): 2 - Ok
Field : 372 Sub : 1 Byte(s): 48 - Ok
Field : 373 Sub : 0 Byte(s): 44 - Ok
Field : 374 Sub : 0 Byte(s): 4 - Ok
Field : 375 Sub : 0 Byte(s): 400 - Ok
Field : 375 Sub : 1 Byte(s): 20 - Ok
Field : 375 Sub : 2 Byte(s): 20 - Ok
Field : 376 Sub : 0 Byte(s): 46 - Ok
Field : 376 Sub : 1 Byte(s): 34 - Ok
Field : 383 Sub : 1 Byte(s): 256 - Ok
Field : 383 Sub : 3 Byte(s): 256 - Ok
Field : 383 Sub : 4 Byte(s): 256 - Ok
Field : 383 Sub : 5 Byte(s): 256 - Ok
Field : 383 Sub : 6 Byte(s): 256 - Ok
Field : 383 Sub : 7 Byte(s): 256 - Ok
Field : 383 Sub : 8 Byte(s): 256 - Ok
Field : 383 Sub : 9 Byte(s): 256 - Ok
Field : 383 Sub : 10 Byte(s): 256 - Ok
Field : 383 Sub : 11 Byte(s): 256 - Ok
Field : 383 Sub : 12 Byte(s): 256 - Ok
Field : 383 Sub : 13 Byte(s): 256 - Ok
Field : 383 Sub : 14 Byte(s): 256 - Ok
Field : 383 Sub : 15 Byte(s): 256 - Ok
Field : 383 Sub : 16 Byte(s): 256 - Ok
Field : 383 Sub : 17 Byte(s): 256 - Ok
Field : 383 Sub : 18 Byte(s): 256 - Ok
Field : 383 Sub : 19 Byte(s): 256 - Ok
Field : 383 Sub : 20 Byte(s): 256 - Ok
Field : 383 Sub : 21 Byte(s): 256 - Ok
Field : 383 Sub : 22 Byte(s): 256 - Ok
Field : 383 Sub : 23 Byte(s): 256 - Ok
Field : 383 Sub : 24 Byte(s): 256 - Ok
Field : 383 Sub : 25 Byte(s): 256 - Ok
Field : 383 Sub : 26 Byte(s): 256 - Ok
Field : 383 Sub : 27 Byte(s): 256 - Ok
Field : 383 Sub : 28 Byte(s): 256 - Ok
Field : 383 Sub : 29 Byte(s): 256 - Ok
Field : 383 Sub : 30 Byte(s): 256 - Ok
Field : 383 Sub : 31 Byte(s): 256 - Ok
Field : 383 Sub : 32 Byte(s): 256 - Ok
Field : 383 Sub : 33 Byte(s): 256 - Ok
Field : 383 Sub : 34 Byte(s): 256 - Ok
Field : 383 Sub : 35 Byte(s): 256 - Ok
Field : 383 Sub : 36 Byte(s): 256 - Ok
Field : 383 Sub : 37 Byte(s): 256 - Ok
Field : 383 Sub : 38 Byte(s): 256 - Ok
Field : 383 Sub : 39 Byte(s): 256 - Ok
Field : 383 Sub : 40 Byte(s): 256 - Ok
Field : 383 Sub : 41 Byte(s): 256 - Ok
Field : 383 Sub : 42 Byte(s): 256 - Ok
Field : 383 Sub : 43 Byte(s): 256 - Ok
Field : 383 Sub : 44 Byte(s): 256 - Ok
Field : 383 Sub : 45 Byte(s): 256 - Ok
Field : 383 Sub : 46 Byte(s): 256 - Ok
Field : 383 Sub : 47 Byte(s): 256 - Ok
Field : 383 Sub : 48 Byte(s): 256 - Ok
Field : 383 Sub : 49 Byte(s): 256 - Ok
Field : 383 Sub : 50 Byte(s): 256 - Ok
Field : 383 Sub : 51 Byte(s): 256 - Ok
Field : 383 Sub : 52 Byte(s): 256 - Ok
Field : 383 Sub : 53 Byte(s): 256 - Ok
Field : 383 Sub : 54 Byte(s): 256 - Ok
Field : 383 Sub : 55 Byte(s): 256 - Ok
Field : 383 Sub : 56 Byte(s): 256 - Ok
Field : 383 Sub : 57 Byte(s): 256 - Ok
Field : 383 Sub : 58 Byte(s): 256 - Ok
Field : 383 Sub : 59 Byte(s): 256 - Ok
Field : 383 Sub : 60 Byte(s): 256 - Ok
Field : 383 Sub : 61 Byte(s): 256 - Ok
Field : 383 Sub : 62 Byte(s): 256 - Ok
Field : 383 Sub : 63 Byte(s): 256 - Ok
Field : 383 Sub : 64 Byte(s): 256 - Ok
Field : 383 Sub : 65 Byte(s): 256 - Ok
Field : 383 Sub : 66 Byte(s): 256 - Ok
Field : 383 Sub : 67 Byte(s): 256 - Ok
Field : 383 Sub : 68 Byte(s): 256 - Ok
Field : 383 Sub : 69 Byte(s): 256 - Ok
Field : 383 Sub : 70 Byte(s): 256 - Ok
Field : 383 Sub : 71 Byte(s): 256 - Ok
Field : 383 Sub : 72 Byte(s): 256 - Ok
Field : 383 Sub : 73 Byte(s): 256 - Ok
Field : 383 Sub : 74 Byte(s): 256 - Ok
Field : 383 Sub : 75 Byte(s): 256 - Ok
Field : 383 Sub : 76 Byte(s): 256 - Ok
Field : 383 Sub : 77 Byte(s): 256 - Ok
Field : 383 Sub : 78 Byte(s): 256 - Ok
Field : 383 Sub : 79 Byte(s): 256 - Ok
Field : 383 Sub : 80 Byte(s): 256 - Ok
Field : 383 Sub : 81 Byte(s): 256 - Ok
Field : 383 Sub : 82 Byte(s): 256 - Ok
Field : 383 Sub : 83 Byte(s): 256 - Ok
Field : 383 Sub : 84 Byte(s): 256 - Ok
Field : 383 Sub : 85 Byte(s): 256 - Ok
Field : 383 Sub : 86 Byte(s): 256 - Ok
Field : 383 Sub : 87 Byte(s): 256 - Ok
Field : 383 Sub : 88 Byte(s): 256 - Ok
Field : 383 Sub : 89 Byte(s): 256 - Ok
Field : 383 Sub : 90 Byte(s): 256 - Ok
Field : 383 Sub : 91 Byte(s): 256 - Ok
Field : 383 Sub : 92 Byte(s): 256 - Ok
Field : 383 Sub : 93 Byte(s): 256 - Ok
Field : 383 Sub : 94 Byte(s): 256 - Ok
Field : 383 Sub : 95 Byte(s): 256 - Ok
Field : 383 Sub : 96 Byte(s): 256 - Ok
Field : 383 Sub : 97 Byte(s): 256 - Ok
Field : 383 Sub : 98 Byte(s): 256 - Ok
Field : 383 Sub : 99 Byte(s): 256 - Ok
Field : 383 Sub : 100 Byte(s): 256 - Ok
Field : 383 Sub : 101 Byte(s): 256 - Ok
Field : 383 Sub : 102 Byte(s): 256 - Ok
Field : 383 Sub : 103 Byte(s): 256 - Ok
Field : 383 Sub : 104 Byte(s): 256 - Ok
Field : 383 Sub : 105 Byte(s): 256 - Ok
Field : 383 Sub : 106 Byte(s): 256 - Ok
Field : 383 Sub : 107 Byte(s): 256 - Ok
Field : 383 Sub : 108 Byte(s): 256 - Ok
Field : 383 Sub : 109 Byte(s): 256 - Ok
Field : 383 Sub : 110 Byte(s): 256 - Ok
Field : 383 Sub : 111 Byte(s): 256 - Ok
Field : 383 Sub : 112 Byte(s): 256 - Ok
Field : 383 Sub : 113 Byte(s): 256 - Ok
Field : 383 Sub : 114 Byte(s): 256 - Ok
Field : 383 Sub : 115 Byte(s): 256 - Ok
Field : 383 Sub : 116 Byte(s): 256 - Ok
Field : 383 Sub : 117 Byte(s): 256 - Ok
Field : 383 Sub : 118 Byte(s): 256 - Ok
Field : 383 Sub : 119 Byte(s): 256 - Ok
Field : 383 Sub : 120 Byte(s): 256 - Ok
Field : 383 Sub : 121 Byte(s): 256 - Ok
Field : 383 Sub : 122 Byte(s): 256 - Ok
Field : 383 Sub : 123 Byte(s): 256 - Ok
Field : 383 Sub : 124 Byte(s): 256 - Ok
Field : 383 Sub : 125 Byte(s): 256 - Ok
Field : 383 Sub : 126 Byte(s): 256 - Ok
Field : 383 Sub : 127 Byte(s): 256 - Ok
Field : 383 Sub : 128 Byte(s): 256 - Ok
Field : 383 Sub : 129 Byte(s): 256 - Ok
Field : 383 Sub : 130 Byte(s): 256 - Ok
Field : 383 Sub : 131 Byte(s): 256 - Ok
Field : 383 Sub : 132 Byte(s): 256 - Ok
Field : 383 Sub : 133 Byte(s): 256 - Ok
Field : 383 Sub : 134 Byte(s): 256 - Ok
Field : 383 Sub : 135 Byte(s): 256 - Ok
Field : 383 Sub : 136 Byte(s): 256 - Ok
Field : 383 Sub : 137 Byte(s): 256 - Ok
Field : 383 Sub : 138 Byte(s): 256 - Ok
Field : 383 Sub : 139 Byte(s): 256 - Ok
Field : 383 Sub : 140 Byte(s): 256 - Ok
Field : 383 Sub : 141 Byte(s): 256 - Ok
Field : 383 Sub : 142 Byte(s): 256 - Ok
Field : 383 Sub : 143 Byte(s): 256 - Ok
Field : 383 Sub : 144 Byte(s): 256 - Ok
Field : 383 Sub : 145 Byte(s): 256 - Ok
Field : 383 Sub : 146 Byte(s): 256 - Ok
Field : 383 Sub : 147 Byte(s): 256 - Ok
Field : 383 Sub : 148 Byte(s): 256 - Ok
Field : 383 Sub : 149 Byte(s): 256 - Ok
Field : 383 Sub : 150 Byte(s): 256 - Ok
Field : 383 Sub : 151 Byte(s): 256 - Ok
Field : 383 Sub : 152 Byte(s): 256 - Ok
Field : 383 Sub : 153 Byte(s): 256 - Ok
Field : 383 Sub : 154 Byte(s): 256 - Ok
Field : 383 Sub : 155 Byte(s): 256 - Ok
Field : 383 Sub : 156 Byte(s): 256 - Ok
Field : 383 Sub : 157 Byte(s): 256 - Ok
Field : 383 Sub : 158 Byte(s): 256 - Ok
Field : 383 Sub : 159 Byte(s): 256 - Ok
Field : 383 Sub : 160 Byte(s): 256 - Ok
Field : 383 Sub : 161 Byte(s): 256 - Ok
Field : 383 Sub : 162 Byte(s): 256 - Ok
Field : 383 Sub : 163 Byte(s): 256 - Ok
Field : 383 Sub : 164 Byte(s): 256 - Ok
Field : 383 Sub : 165 Byte(s): 256 - Ok
Field : 383 Sub : 166 Byte(s): 256 - Ok
Field : 383 Sub : 167 Byte(s): 256 - Ok
Field : 383 Sub : 168 Byte(s): 256 - Ok
Field : 383 Sub : 169 Byte(s): 256 - Ok
Field : 383 Sub : 170 Byte(s): 256 - Ok
Field : 383 Sub : 171 Byte(s): 256 - Ok
Field : 383 Sub : 172 Byte(s): 256 - Ok
Field : 390 Sub : 0 Byte(s): 256 - Ok
Field : 390 Sub : 1 Byte(s): 256 - Ok
Field : 390 Sub : 2 Byte(s): 256 - Ok
Field : 390 Sub : 3 Byte(s): 256 - Ok
Field : 390 Sub : 4 Byte(s): 256 - Ok
Field : 390 Sub : 5 Byte(s): 256 - Ok
Field : 390 Sub : 6 Byte(s): 256 - Ok
Field : 390 Sub : 7 Byte(s): 256 - Ok
Field : 390 Sub : 8 Byte(s): 256 - Ok
Field : 390 Sub : 9 Byte(s): 256 - Ok
Field : 390 Sub : 10 Byte(s): 256 - Ok
Field : 390 Sub : 11 Byte(s): 256 - Ok
Field : 390 Sub : 12 Byte(s): 256 - Ok
Field : 390 Sub : 13 Byte(s): 256 - Ok
Field : 390 Sub : 14 Byte(s): 256 - Ok
Field : 390 Sub : 15 Byte(s): 256 - Ok
Field : 390 Sub : 16 Byte(s): 256 - Ok
Field : 390 Sub : 17 Byte(s): 256 - Ok
Field : 390 Sub : 18 Byte(s): 256 - Ok
Field : 390 Sub : 19 Byte(s): 256 - Ok
Field : 390 Sub : 20 Byte(s): 256 - Ok
Field : 390 Sub : 21 Byte(s): 256 - Ok
Field : 390 Sub : 22 Byte(s): 256 - Ok
Field : 390 Sub : 23 Byte(s): 256 - Ok
Field : 390 Sub : 24 Byte(s): 256 - Ok
Field : 390 Sub : 25 Byte(s): 256 - Ok
Field : 390 Sub : 26 Byte(s): 256 - Ok
Field : 390 Sub : 27 Byte(s): 256 - Ok
Field : 390 Sub : 28 Byte(s): 256 - Ok
Field : 390 Sub : 29 Byte(s): 256 - Ok
Field : 390 Sub : 30 Byte(s): 256 - Ok
Field : 390 Sub : 31 Byte(s): 256 - Ok
Field : 390 Sub : 32 Byte(s): 256 - Ok
Field : 390 Sub : 33 Byte(s): 256 - Ok
Field : 390 Sub : 34 Byte(s): 256 - Ok
Field : 390 Sub : 35 Byte(s): 256 - Ok
Field : 390 Sub : 36 Byte(s): 256 - Ok
Field : 390 Sub : 37 Byte(s): 256 - Ok
Field : 390 Sub : 38 Byte(s): 256 - Ok
Field : 390 Sub : 39 Byte(s): 256 - Ok
Field : 390 Sub : 40 Byte(s): 256 - Ok
Field : 390 Sub : 41 Byte(s): 256 - Ok
Field : 390 Sub : 42 Byte(s): 256 - Ok
Field : 390 Sub : 43 Byte(s): 256 - Ok
Field : 390 Sub : 44 Byte(s): 256 - Ok
Field : 390 Sub : 45 Byte(s): 256 - Ok
Field : 390 Sub : 46 Byte(s): 256 - Ok
Field : 390 Sub : 47 Byte(s): 256 - Ok
Field : 390 Sub : 48 Byte(s): 256 - Ok
Field : 390 Sub : 49 Byte(s): 256 - Ok
Field : 390 Sub : 50 Byte(s): 256 - Ok
Field : 390 Sub : 51 Byte(s): 256 - Ok
Field : 390 Sub : 52 Byte(s): 256 - Ok
Field : 390 Sub : 53 Byte(s): 256 - Ok
Field : 390 Sub : 54 Byte(s): 256 - Ok
Field : 390 Sub : 55 Byte(s): 256 - Ok
Field : 390 Sub : 56 Byte(s): 256 - Ok
Field : 390 Sub : 57 Byte(s): 256 - Ok
Field : 390 Sub : 58 Byte(s): 256 - Ok
Field : 390 Sub : 59 Byte(s): 256 - Ok
Field : 390 Sub : 60 Byte(s): 256 - Ok
Field : 390 Sub : 61 Byte(s): 256 - Ok
Field : 390 Sub : 62 Byte(s): 256 - Ok
Field : 390 Sub : 63 Byte(s): 256 - Ok
Field : 390 Sub : 64 Byte(s): 256 - Ok
Field : 390 Sub : 65 Byte(s): 256 - Ok
Field : 390 Sub : 66 Byte(s): 256 - Ok
Field : 390 Sub : 67 Byte(s): 256 - Ok
Field : 390 Sub : 68 Byte(s): 256 - Ok
Field : 390 Sub : 69 Byte(s): 256 - Ok
Field : 390 Sub : 70 Byte(s): 256 - Ok
Field : 390 Sub : 71 Byte(s): 256 - Ok
Field : 390 Sub : 72 Byte(s): 256 - Ok
Field : 390 Sub : 73 Byte(s): 256 - Ok
Field : 390 Sub : 74 Byte(s): 256 - Ok
Field : 390 Sub : 75 Byte(s): 256 - Ok
Field : 390 Sub : 76 Byte(s): 256 - Ok
Field : 390 Sub : 77 Byte(s): 256 - Ok
Field : 390 Sub : 78 Byte(s): 256 - Ok
Field : 390 Sub : 79 Byte(s): 256 - Ok
Field : 390 Sub : 80 Byte(s): 256 - Ok
Field : 390 Sub : 81 Byte(s): 256 - Ok
Field : 390 Sub : 82 Byte(s): 256 - Ok
Field : 390 Sub : 83 Byte(s): 256 - Ok
Field : 390 Sub : 84 Byte(s): 256 - Ok
Field : 390 Sub : 85 Byte(s): 256 - Ok
Field : 390 Sub : 86 Byte(s): 256 - Ok
Field : 390 Sub : 87 Byte(s): 256 - Ok
Field : 390 Sub : 88 Byte(s): 256 - Ok
Field : 390 Sub : 89 Byte(s): 256 - Ok
Field : 390 Sub : 90 Byte(s): 256 - Ok
Field : 390 Sub : 91 Byte(s): 256 - Ok
Field : 390 Sub : 92 Byte(s): 256 - Ok
Field : 390 Sub : 93 Byte(s): 256 - Ok
Field : 390 Sub : 94 Byte(s): 256 - Ok
Field : 390 Sub : 95 Byte(s): 256 - Ok
Field : 390 Sub : 96 Byte(s): 256 - Ok
Field : 390 Sub : 97 Byte(s): 256 - Ok
Field : 390 Sub : 98 Byte(s): 256 - Ok
Field : 390 Sub : 99 Byte(s): 256 - Ok
Field : 390 Sub : 100 Byte(s): 256 - Ok
Field : 390 Sub : 101 Byte(s): 256 - Ok
Field : 390 Sub : 102 Byte(s): 256 - Ok
Field : 390 Sub : 103 Byte(s): 256 - Ok
Field : 390 Sub : 104 Byte(s): 256 - Ok
Field : 390 Sub : 105 Byte(s): 256 - Ok
Field : 390 Sub : 106 Byte(s): 256 - Ok
Field : 390 Sub : 107 Byte(s): 256 - Ok
Field : 390 Sub : 108 Byte(s): 256 - Ok
Field : 390 Sub : 109 Byte(s): 256 - Ok
Field : 390 Sub : 110 Byte(s): 256 - Ok
Field : 390 Sub : 111 Byte(s): 256 - Ok
Field : 390 Sub : 112 Byte(s): 256 - Ok
Field : 390 Sub : 113 Byte(s): 256 - Ok
Field : 390 Sub : 114 Byte(s): 256 - Ok
Field : 390 Sub : 115 Byte(s): 256 - Ok
Field : 390 Sub : 116 Byte(s): 256 - Ok
Field : 390 Sub : 117 Byte(s): 256 - Ok
Field : 390 Sub : 118 Byte(s): 256 - Ok
Field : 390 Sub : 119 Byte(s): 256 - Ok
Field : 390 Sub : 120 Byte(s): 256 - Ok
Field : 390 Sub : 121 Byte(s): 256 - Ok
Field : 390 Sub : 122 Byte(s): 256 - Ok
Field : 390 Sub : 123 Byte(s): 256 - Ok
Field : 390 Sub : 124 Byte(s): 256 - Ok
Field : 390 Sub : 125 Byte(s): 256 - Ok
Field : 390 Sub : 126 Byte(s): 256 - Ok
Field : 390 Sub : 127 Byte(s): 256 - Ok
Field : 390 Sub : 128 Byte(s): 256 - Ok
Field : 390 Sub : 129 Byte(s): 256 - Ok
Field : 390 Sub : 130 Byte(s): 256 - Ok
Field : 390 Sub : 131 Byte(s): 256 - Ok
Field : 390 Sub : 133 Byte(s): 256 - Ok
Field : 390 Sub : 134 Byte(s): 256 - Ok
Field : 390 Sub : 135 Byte(s): 256 - Ok
Field : 390 Sub : 136 Byte(s): 256 - Ok
Field : 390 Sub : 137 Byte(s): 256 - Ok
Field : 390 Sub : 138 Byte(s): 256 - Ok
Field : 390 Sub : 139 Byte(s): 256 - Ok
Field : 390 Sub : 140 Byte(s): 256 - Ok
Field : 390 Sub : 141 Byte(s): 256 - Ok
Field : 390 Sub : 142 Byte(s): 256 - Ok
Field : 390 Sub : 143 Byte(s): 256 - Ok
Field : 390 Sub : 144 Byte(s): 256 - Ok
Field : 390 Sub : 145 Byte(s): 256 - Ok
Field : 390 Sub : 146 Byte(s): 256 - Ok
Field : 390 Sub : 147 Byte(s): 256 - Ok
Field : 390 Sub : 148 Byte(s): 256 - Ok
Field : 390 Sub : 149 Byte(s): 256 - Ok
Field : 390 Sub : 150 Byte(s): 256 - Ok
Field : 390 Sub : 151 Byte(s): 256 - Ok
Field : 390 Sub : 152 Byte(s): 256 - Ok
Field : 390 Sub : 153 Byte(s): 256 - Ok
Field : 390 Sub : 154 Byte(s): 256 - Ok
Field : 390 Sub : 155 Byte(s): 256 - Ok
Field : 390 Sub : 156 Byte(s): 256 - Ok
Field : 390 Sub : 157 Byte(s): 256 - Ok
Field : 390 Sub : 158 Byte(s): 256 - Ok
Field : 390 Sub : 159 Byte(s): 256 - Ok
Field : 390 Sub : 160 Byte(s): 256 - Ok
Field : 390 Sub : 161 Byte(s): 256 - Ok
Field : 390 Sub : 162 Byte(s): 256 - Ok
Field : 390 Sub : 163 Byte(s): 256 - Ok
Field : 390 Sub : 164 Byte(s): 256 - Ok
Field : 390 Sub : 165 Byte(s): 256 - Ok
Field : 390 Sub : 166 Byte(s): 256 - Ok
Field : 390 Sub : 167 Byte(s): 256 - Ok
Field : 390 Sub : 168 Byte(s): 256 - Ok
Field : 390 Sub : 169 Byte(s): 256 - Ok
Field : 390 Sub : 170 Byte(s): 256 - Ok
Field : 390 Sub : 171 Byte(s): 256 - Ok
Field : 390 Sub : 172 Byte(s): 256 - Ok
Field : 390 Sub : 173 Byte(s): 256 - Ok
Field : 390 Sub : 174 Byte(s): 256 - Ok
Field : 390 Sub : 175 Byte(s): 256 - Ok
Field : 390 Sub : 176 Byte(s): 256 - Ok
Field : 390 Sub : 177 Byte(s): 256 - Ok
Field : 390 Sub : 178 Byte(s): 256 - Ok
Field : 390 Sub : 179 Byte(s): 256 - Ok
Field : 390 Sub : 180 Byte(s): 256 - Ok
Field : 390 Sub : 181 Byte(s): 256 - Ok
Field : 390 Sub : 182 Byte(s): 256 - Ok
Field : 390 Sub : 183 Byte(s): 256 - Ok
Field : 390 Sub : 184 Byte(s): 256 - Ok
Field : 390 Sub : 185 Byte(s): 256 - Ok
Field : 390 Sub : 186 Byte(s): 256 - Ok
Field : 390 Sub : 187 Byte(s): 256 - Ok
Field : 390 Sub : 188 Byte(s): 256 - Ok
Field : 390 Sub : 189 Byte(s): 256 - Ok
Field : 390 Sub : 190 Byte(s): 256 - Ok
Field : 390 Sub : 191 Byte(s): 256 - Ok
Field : 390 Sub : 192 Byte(s): 256 - Ok
Field : 390 Sub : 193 Byte(s): 256 - Ok
Field : 390 Sub : 194 Byte(s): 256 - Ok
Field : 390 Sub : 195 Byte(s): 256 - Ok
Field : 390 Sub : 196 Byte(s): 256 - Ok
Field : 390 Sub : 197 Byte(s): 256 - Ok
Field : 390 Sub : 198 Byte(s): 256 - Ok
Field : 390 Sub : 199 Byte(s): 256 - Ok
Field : 390 Sub : 200 Byte(s): 256 - Ok
Field : 390 Sub : 201 Byte(s): 256 - Ok
Field : 390 Sub : 202 Byte(s): 256 - Ok
Field : 390 Sub : 203 Byte(s): 256 - Ok
Field : 390 Sub : 204 Byte(s): 256 - Ok
Field : 390 Sub : 205 Byte(s): 256 - Ok
Field : 390 Sub : 206 Byte(s): 256 - Ok
Field : 390 Sub : 207 Byte(s): 256 - Ok
Field : 390 Sub : 208 Byte(s): 256 - Ok
Field : 390 Sub : 209 Byte(s): 256 - Ok
Field : 390 Sub : 210 Byte(s): 256 - Ok
Field : 390 Sub : 211 Byte(s): 256 - Ok
Field : 390 Sub : 212 Byte(s): 256 - Ok
Field : 390 Sub : 213 Byte(s): 256 - Ok
Field : 390 Sub : 214 Byte(s): 256 - Ok
Field : 390 Sub : 215 Byte(s): 256 - Ok
Field : 390 Sub : 216 Byte(s): 256 - Ok
Field : 390 Sub : 217 Byte(s): 256 - Ok
Field : 390 Sub : 218 Byte(s): 256 - Ok
Field : 390 Sub : 219 Byte(s): 256 - Ok
Field : 390 Sub : 220 Byte(s): 256 - Ok
Field : 390 Sub : 221 Byte(s): 256 - Ok
Field : 390 Sub : 222 Byte(s): 256 - Ok
Field : 390 Sub : 223 Byte(s): 256 - Ok
Field : 390 Sub : 224 Byte(s): 256 - Ok
Field : 390 Sub : 225 Byte(s): 256 - Ok
Field : 390 Sub : 226 Byte(s): 256 - Ok
Field : 390 Sub : 227 Byte(s): 256 - Ok
Field : 390 Sub : 228 Byte(s): 256 - Ok
Field : 390 Sub : 229 Byte(s): 256 - Ok
Field : 390 Sub : 230 Byte(s): 256 - Ok
Field : 390 Sub : 231 Byte(s): 256 - Ok
Field : 390 Sub : 232 Byte(s): 256 - Ok
Field : 390 Sub : 233 Byte(s): 256 - Ok
Field : 390 Sub : 234 Byte(s): 256 - Ok
Field : 390 Sub : 235 Byte(s): 256 - Ok
Field : 390 Sub : 236 Byte(s): 256 - Ok
Field : 390 Sub : 237 Byte(s): 256 - Ok
Field : 390 Sub : 238 Byte(s): 256 - Ok
Field : 390 Sub : 239 Byte(s): 256 - Ok
Field : 390 Sub : 240 Byte(s): 256 - Ok
Field : 390 Sub : 241 Byte(s): 256 - Ok
Field : 390 Sub : 242 Byte(s): 256 - Ok
Field : 390 Sub : 243 Byte(s): 256 - Ok
Field : 390 Sub : 244 Byte(s): 256 - Ok
Field : 390 Sub : 245 Byte(s): 256 - Ok
Field : 390 Sub : 246 Byte(s): 256 - Ok
Field : 390 Sub : 247 Byte(s): 256 - Ok
Field : 390 Sub : 248 Byte(s): 256 - Ok
Field : 390 Sub : 249 Byte(s): 256 - Ok
Field : 390 Sub : 250 Byte(s): 256 - Ok
Field : 390 Sub : 251 Byte(s): 256 - Ok
Field : 390 Sub : 252 Byte(s): 256 - Ok
Field : 390 Sub : 253 Byte(s): 256 - Ok
Field : 391 Sub : 0 Byte(s): 256 - Ok
Field : 391 Sub : 2 Byte(s): 256 - Ok
Field : 391 Sub : 3 Byte(s): 256 - Ok
Field : 391 Sub : 4 Byte(s): 256 - Ok
Field : 391 Sub : 5 Byte(s): 256 - Ok
Field : 391 Sub : 6 Byte(s): 256 - Ok
Field : 391 Sub : 7 Byte(s): 256 - Ok
Field : 391 Sub : 8 Byte(s): 256 - Ok
Field : 391 Sub : 9 Byte(s): 256 - Ok
Field : 391 Sub : 10 Byte(s): 256 - Ok
Field : 391 Sub : 11 Byte(s): 256 - Ok
Field : 391 Sub : 12 Byte(s): 256 - Ok
Field : 391 Sub : 13 Byte(s): 256 - Ok
Field : 391 Sub : 14 Byte(s): 256 - Ok
Field : 391 Sub : 15 Byte(s): 256 - Ok
Field : 391 Sub : 16 Byte(s): 256 - Ok
Field : 391 Sub : 17 Byte(s): 256 - Ok
Field : 391 Sub : 18 Byte(s): 256 - Ok
Field : 391 Sub : 19 Byte(s): 256 - Ok
Field : 391 Sub : 20 Byte(s): 256 - Ok
Field : 391 Sub : 21 Byte(s): 256 - Ok
Field : 391 Sub : 22 Byte(s): 256 - Ok
Field : 391 Sub : 23 Byte(s): 256 - Ok
Field : 391 Sub : 24 Byte(s): 256 - Ok
Field : 391 Sub : 25 Byte(s): 256 - Ok
Field : 391 Sub : 26 Byte(s): 256 - Ok
Field : 391 Sub : 27 Byte(s): 256 - Ok
Field : 391 Sub : 28 Byte(s): 256 - Ok
Field : 391 Sub : 29 Byte(s): 256 - Ok
Field : 391 Sub : 30 Byte(s): 256 - Ok
Field : 391 Sub : 31 Byte(s): 256 - Ok
Field : 391 Sub : 32 Byte(s): 256 - Ok
Field : 391 Sub : 33 Byte(s): 256 - Ok
Field : 391 Sub : 34 Byte(s): 256 - Ok
Field : 391 Sub : 35 Byte(s): 256 - Ok
Field : 391 Sub : 36 Byte(s): 256 - Ok
Field : 391 Sub : 37 Byte(s): 256 - Ok
Field : 391 Sub : 38 Byte(s): 256 - Ok
Field : 391 Sub : 39 Byte(s): 256 - Ok
Field : 391 Sub : 40 Byte(s): 256 - Ok
Field : 391 Sub : 41 Byte(s): 256 - Ok
Field : 391 Sub : 42 Byte(s): 256 - Ok
Field : 391 Sub : 43 Byte(s): 256 - Ok
Field : 391 Sub : 44 Byte(s): 256 - Ok
Field : 391 Sub : 45 Byte(s): 256 - Ok
Field : 391 Sub : 46 Byte(s): 256 - Ok
Field : 391 Sub : 47 Byte(s): 256 - Ok
Field : 391 Sub : 48 Byte(s): 256 - Ok
Field : 391 Sub : 49 Byte(s): 256 - Ok
Field : 391 Sub : 50 Byte(s): 256 - Ok
Field : 391 Sub : 51 Byte(s): 256 - Ok
Field : 391 Sub : 52 Byte(s): 256 - Ok
Field : 391 Sub : 53 Byte(s): 256 - Ok
Field : 391 Sub : 54 Byte(s): 256 - Ok
Field : 391 Sub : 55 Byte(s): 256 - Ok
Field : 391 Sub : 56 Byte(s): 256 - Ok
Field : 391 Sub : 57 Byte(s): 256 - Ok
Field : 391 Sub : 58 Byte(s): 256 - Ok
Field : 391 Sub : 59 Byte(s): 256 - Ok
Field : 391 Sub : 60 Byte(s): 256 - Ok
Field : 391 Sub : 61 Byte(s): 256 - Ok
Field : 391 Sub : 62 Byte(s): 256 - Ok
Field : 391 Sub : 63 Byte(s): 256 - Ok
Field : 391 Sub : 64 Byte(s): 256 - Ok
Field : 391 Sub : 65 Byte(s): 256 - Ok
Field : 391 Sub : 66 Byte(s): 256 - Ok
Field : 391 Sub : 67 Byte(s): 256 - Ok
Field : 391 Sub : 68 Byte(s): 256 - Ok
Field : 391 Sub : 69 Byte(s): 256 - Ok
Field : 391 Sub : 70 Byte(s): 256 - Ok
Field : 391 Sub : 71 Byte(s): 256 - Ok
Field : 391 Sub : 72 Byte(s): 256 - Ok
Field : 391 Sub : 73 Byte(s): 256 - Ok
Field : 391 Sub : 74 Byte(s): 256 - Ok
Field : 391 Sub : 75 Byte(s): 256 - Ok
Field : 391 Sub : 76 Byte(s): 256 - Ok
Field : 391 Sub : 77 Byte(s): 256 - Ok
Field : 391 Sub : 78 Byte(s): 256 - Ok
Field : 391 Sub : 79 Byte(s): 256 - Ok
Field : 391 Sub : 80 Byte(s): 256 - Ok
Field : 391 Sub : 81 Byte(s): 256 - Ok
Field : 391 Sub : 82 Byte(s): 256 - Ok
Field : 391 Sub : 83 Byte(s): 256 - Ok
Field : 391 Sub : 84 Byte(s): 256 - Ok
Field : 391 Sub : 85 Byte(s): 256 - Ok
Field : 391 Sub : 86 Byte(s): 256 - Ok
Field : 391 Sub : 87 Byte(s): 256 - Ok
Field : 391 Sub : 88 Byte(s): 256 - Ok
Field : 391 Sub : 89 Byte(s): 256 - Ok
Field : 391 Sub : 90 Byte(s): 256 - Ok
Field : 391 Sub : 91 Byte(s): 256 - Ok
Field : 391 Sub : 92 Byte(s): 256 - Ok
Field : 391 Sub : 93 Byte(s): 256 - Ok
Field : 391 Sub : 94 Byte(s): 256 - Ok
Field : 391 Sub : 95 Byte(s): 256 - Ok
Field : 391 Sub : 96 Byte(s): 256 - Ok
Field : 391 Sub : 97 Byte(s): 256 - Ok
Field : 391 Sub : 98 Byte(s): 256 - Ok
Field : 391 Sub : 99 Byte(s): 256 - Ok
Field : 391 Sub : 100 Byte(s): 256 - Ok
Field : 391 Sub : 101 Byte(s): 256 - Ok
Field : 391 Sub : 102 Byte(s): 256 - Ok
Field : 391 Sub : 103 Byte(s): 256 - Ok
Field : 391 Sub : 104 Byte(s): 256 - Ok
Field : 391 Sub : 105 Byte(s): 256 - Ok
Field : 391 Sub : 106 Byte(s): 256 - Ok
Field : 391 Sub : 107 Byte(s): 256 - Ok
Field : 391 Sub : 108 Byte(s): 256 - Ok
Field : 391 Sub : 109 Byte(s): 256 - Ok
Field : 391 Sub : 110 Byte(s): 256 - Ok
Field : 391 Sub : 111 Byte(s): 256 - Ok
Field : 391 Sub : 112 Byte(s): 256 - Ok
Field : 391 Sub : 113 Byte(s): 256 - Ok
Field : 391 Sub : 114 Byte(s): 256 - Ok
Field : 391 Sub : 115 Byte(s): 256 - Ok
Field : 391 Sub : 116 Byte(s): 256 - Ok
Field : 391 Sub : 117 Byte(s): 256 - Ok
Field : 391 Sub : 118 Byte(s): 256 - Ok
Field : 391 Sub : 119 Byte(s): 256 - Ok
Field : 391 Sub : 120 Byte(s): 256 - Ok
Field : 391 Sub : 121 Byte(s): 256 - Ok
Field : 391 Sub : 122 Byte(s): 256 - Ok
Field : 391 Sub : 123 Byte(s): 256 - Ok
Field : 391 Sub : 124 Byte(s): 256 - Ok
Field : 391 Sub : 125 Byte(s): 256 - Ok
Field : 391 Sub : 126 Byte(s): 256 - Ok
Field : 391 Sub : 127 Byte(s): 256 - Ok
Field : 391 Sub : 128 Byte(s): 256 - Ok
Field : 391 Sub : 129 Byte(s): 256 - Ok
Field : 391 Sub : 130 Byte(s): 256 - Ok
Field : 391 Sub : 131 Byte(s): 256 - Ok
Field : 391 Sub : 132 Byte(s): 256 - Ok
Field : 391 Sub : 133 Byte(s): 256 - Ok
Field : 391 Sub : 134 Byte(s): 256 - Ok
Field : 391 Sub : 135 Byte(s): 256 - Ok
Field : 391 Sub : 136 Byte(s): 256 - Ok
Field : 391 Sub : 137 Byte(s): 256 - Ok
Field : 391 Sub : 138 Byte(s): 256 - Ok
Field : 391 Sub : 139 Byte(s): 256 - Ok
Field : 391 Sub : 140 Byte(s): 256 - Ok
Field : 391 Sub : 141 Byte(s): 256 - Ok
Field : 391 Sub : 142 Byte(s): 256 - Ok
Field : 391 Sub : 143 Byte(s): 256 - Ok
Field : 391 Sub : 144 Byte(s): 256 - Ok
PM Upload Done!...
Phone Model: K C2-02
Category : Phone
Phone Type : RM-693
Product Serial Number: B2560D0AI
Product Code : 059D331
Module Code : 0204666
Basic Production Code: 0593195
HW Version : 2000
LCD Version : TPO
FWID Version : iV 06.96 09-09-11 RM-693 (c) Nokia V 06.96 09-09-11 RM-692 (c) Nokia H 059D331 001
ASIC : 11
SECURITY_CODE : 00852
PHONE_MODE : TEST
DCC ID : 06150123
DCC Ver: 007025
Status : OK
PM RM-692==>>RM-692 C2-02.pm
