xin giúp log nokia 6300 ?
minh nhan máy nokia 6300 bi treo may tự khởi động lại , mang qua mx-key chạy thì báo :
Version from phone: 07.30
Version from file: 07.30
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0859251
Using device: HTI, FW ver: 00.50, SN: 00008BBA
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1BB00013EA6E6B56BD49A9B358B09526F71EF9D9
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 00EC 22FE - 0000 6921 [Samsung K8S5615ETA,256 Mbits] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
PRIVATE ID: 001F22C1EF288A334965D71ED76B8BE1EB1452BE
E-FUSE: 719402F7
SEC ROM CRC: DFAAF68F
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
eBB5ProtocolType: OLD
Storage0: 00EC 22FE - 0000 6921 [Samsung K8S5615ETA,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Flash Imei: 35696001636560
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35696001636560_BA CK.rpl"
Processing MCU file: rm217__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 1 min 40.953 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 35.219 s
Processing PPM file: rm217__07.21.ppm_v
[BB5,BB5 ALGORITHM] size: 5.16 MB
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 5.50 MB
CMT FLASH,NOR area [01080000-015FFFFF]
erased in 35.766 s
NOR: OK
NOR: OK
Programming completed in 36.110 s
Processing CNT file: rm217__07.30_ISM_003.image_b_black_ctv_pl
[BB5,BB5 ALGORITHM] page size: 64 K size: 4.32 MB
NOR page size in the phone is 64 K.
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 9.87 MB
CMT FLASH,NOR area [01600000-01FDFFFF]
erased in 51.219 s
NOR: OK
NOR: OK
Programming completed in 30.032 s
Total time for flashing process(boot+erase+write) was 6 min 25.141 s
Phone type: RM-217 (Nokia 6300)
SW version: V 07.30 07-05-09 RM-217 (c) Nokia.
Imei plain: 35696001636560-8
Product code: 0554580
Battery voltage: 4011 mV, current: 148 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356960016365608
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
bây giờ mở nguồn vẫn bị treo và khởi động lại . bạn nào gặp qua chỉ mình với mình cảm ơn !
