cần anh em giúp asha 305 bật nguồn chớp nokia tắt
đây là quá trình em chạy Number of Image Files: 3
Processing Image File :
rm766__03.60.mcusw
rm766__03.60.ppm_v
rm766__03.60.image_v_059L0H5
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: 1210180D9518280E
Original Product Code: 059L0V3
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\354131056767549\3541310567675 49_25845.rpl
Data Sections : 04
Current File : rm766__03.60.mcusw
Compile Name: rm766__03.60.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 29117832 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 1369
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 73CD
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4011FFFE
Start Erasing...
Block Erase Done...
Data Size: 786432 bytes
Data Checksum: 6A2F
Processing Section 04
FIRMWARE Erase Block: 0x40120000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 28065792 bytes
Data Checksum: DF12
Processing Section 05
FIRMWARE Erase Block: 0x43EE0000~0x43EFFFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm766__03.60.ppm_v
Compile Name: package_v.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 7757988 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41C00000~0x423FFFFE
Start Erasing...
Block Erase Done...
Data Size: 7754644 bytes
Data Checksum: 9591
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm766__03.60.image_v_059L0H5
Compile Name: package_v_059L0H5.image.fls
Image Type : CONTENT Package
Data Size : 12848400 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42400000~0x43EDFFFE
Start Erasing...
Block Erase Done...
Data Size: 12845056 bytes
Data Checksum: AABA
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43F00000~0x43F7FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:05:32
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
WARNING: Phone is not in the Required Mode...
Disconnect the Phone and Power it Up Manually.
Scanning USB Ports...
ERROR: Active Phone Handle was NOT DETECTED
TIP: Make sure that Phone USB Connection Mode is
OVI Suite Mode
or
PC Suite Mode
