1600 contacservice chạy hoài không hết
1600 info bằng jaf 1.98.63.hiển thị imei 14 số ở góc bên phải.mà hình nổi chử testmode,nhưng vẫn bị contacservic.mong anh em chỉ dùm em.đây là log của nó.cám ơn mấy anh trước nha:
MCU ID: 0x2031
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-64
(c) NMP
HW version: 0526
PCI version:
UEM version: 1328
UPP version: 8241
RFIC version: 0500
DSP version: P05w06.v34
LCD version: SDI:NAXv89
S6B33BD
PPM version: V 7.02
10-12-07
RH-64
(c) NMP
MD
ADSP SW version: V 7.02\n10-12-07\nRH-64\n(c) NMP\nmd
Production serial number: IDD318239
Product code: 0525397
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352751011294974
IMEI spare to net: 3A 25 57 01 11 92 94 07
IMEI SV to net: 33 25 57 01 11 92 94 47 F5
Master Code: 2024226607
Phone type: RH-64, Software version: 7.02, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini
Setting local mode...
Reading product code...
Product Code: 0525397
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02md
Languages in ppm: English,Filipino,Vietnamase
Done!
rh-64 ver7.02 35275101129497X
thiếu mất số 4 ở vị trí(x).các anh giúp em với,thank you trước nha.
