cần giúp 6230 mất nguồn do gì ko bít,
Getting MCU ID
MCU ID: 0x1052
FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05.50
07-07-05
RH-12
GSM P1.1
(c) NMP.
HW version: 0600
PCI version:
UEM version: 288
UPP version: 4178
RFIC version: p
10ff11ff0203
DSP version: p
B0435T_04w46
LCD version: SHARP
PPM version: V 05.50
07-07-05
RH12_28_-
GSM P1.1
V
BT MCM version: 0380
ADSP SW version: MATRIX_04_w35_prod_w46
Production serial number: CGD085900
Product code: 0514064
Module code: 0201879
Basic production code: 0509076
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352951005375439
IMEI spare to net: 3A 25 59 01 50 73 45 03
IMEI SV to net: 33 25 59 01 50 73 45 13 F7
Master Code: 2306222641
Phone type: RH-12, Software version: 05.50, Language Pack: V
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-12.ini
Setting local mode...
Reading product code...
Product Code: 0514064
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-12\
Checking path: \Products\RH-12\
No ini files found...
Done!
